Oil sending unit
Status
Not open for further replies.
Don S
All I did was replace oil sensing unit and valve cover gasket on driver side yesterday. Started right back up, started hearing loud loud tick. This motor is the quietest ever made. Makes no sense. I shut it off immediately. Reached back inside and tapped the key and heard a very loud smack. What in the world? Can new screen be installed wrong and be blocking off oil passage to the lifters or what’s the deal? Only vehicle and runs flawlessly for over 8 years, never fails. 2007 Chevy Tahoe 5.3 wit 335k. Oil pressure on gauge went up to 50
Chris2144
With everything you have described I would be pulling the valve cover back off and checking for a dropped valve.
Maybe a rocker came off the push rod.
mikez71
Even if the AFM oil passage was blocked, your truck would not activate AFM at cold start idle.
I once left tape on an intake port.. Just one out of 8.. ???
Threw the intake on and started it. 'flap, flap, flap, flap!'
Removed the intake and luckily the tape was still intact.
Never underestimate your ability to lose stuff!
If you're me anyway...
mikez71
Apparently he has taken cover off, found nothing.
Original thread here..
Chris2144
I was under the assumption that this happened after he put it back together and from the sound of it I would take it back off to inspect
Marky Dissod
Apparently he has taken cover off, found nothing. Original thread here.
@Fless, can you merge these threads?
Sorry, no, I don't have that ability. But I'll lock this one and reference the other:
Status
scottd
