They are ebay housings that I stuffed MH1's into.
Was the retrofit easy because I have a set of MH1’s that are etched to look like eyes that I’m looking to use. I was going to open my Silverado headlights again and swap them in on a quad retrofit but decided nah.
Bought a few parts for the Tahoe the last few days: smooth black door handles and mirror caps to start on a chrome delete and I found an esky roof rack in the color I needed for $100. Still deciding on head and tail lights. I have half a can plus more silver birch metallic paint on order so now I’m trying to decide on how much to color match and what to leave as is. Actually I already know I’m painting the chrome on the roof rack and the mirror caps so the only question is the door handles. I can disassemble them and paint them. But I think I’ll install them black first just to see. I’m kind of busy this time of year so I might paint the handles another time. I just finished this border and raised veggie bed yesterday and my pond is coming along,
Geoffsfas10
St. Louis
SUPER easy
Charlie207
LFOD, New Hampshire
Just that the factory rocker bearings are stout. I’ve never read of one losing its needles since some early LS1’s had some problems with it. It’s a non-issue with the LS3 motors unless you’re running a huge cam.
I cut the connector off it, and split it out to each individual wire. Then I used heat shrink tubing on each wire end, and then folded it over on itself, and use a big piece of heat shrink tubing for the entire thing to make it completely waterproof.
I'll just add that I'm a fan of Richard Holdener, so take it with a grain of salt, but he's said that there's no reason to upgrade the trunions unless they have failed. He's basically a professional LS dyno tester, and if he's not particularly concerned while beating the tar out of junkyard turbo builds, I'm not worried.
Charlie207
LFOD, New Hampshire
Hi All - Appreciate your time reading this in advance. Below is my current purchased parts list for the DoD+VVT delete. Anything you see here I might be missing?
I've bought all of this so far, currently dismantling the car and hope to move onto install phase next week.
GM OEMGM LS Lifter Tray (set of 4)
GM OEMGM-19420455GM 19420455 Single Beehive Valve Spring Set
GM OEMLS Valve Seals For Beehive Springs & Factory Guides, Set of 16
Cam MotionPS174001204LS Hardened Chrome-Moly Pushrods (5/16" diameter, .080" wall) | Pushrod Length: 7.400" Long
ARP134-1003ARP 134-1003 Cam to Timing Gear Bolts
Cam MotionSKU: 03-01-00306.2 Stage 1 LS Truck Camshaft (206/216-117+4)
- *"drop-in" version for use with stock valve springs
- *3-bolt 5150 steel alloy - $400
GM OEM12673134Oil Pressure Switch
Mahle54660MLS Head Gasket
MahleMS19598Intake Manifold Gasket
GM OEM12640746Engine Oil Pan
MellingM365HV395SHigh-volume Oil Pump + Oil Pickup Tube assembly
GM OEM2133826Camshaft Position Sensor
GM OEM12703627Crankshaft Position Sensor
ACDelco41162ACDelco [GM OEM] Spark plugs - x8
MahleMF127Camshaft Retainer/Thrust Plate
GM OEM12626407Timing Chain Tensioner
ARP134-3610Cylinder head / head stud bolts
Brian Tooley RacingTK001NBRocker Arm Trunnion Upgrade Kits
Trick FlowTFS-30678505VVT Delete Combo Kit
ICT BilletWAVVT40-10LS VVT to Non-VVT Camshaft Sensor Adaptor
Chevrolet Performance12598832Engine Valley Cover
Chevrolet Performance12499225Hydraulic Roller Lifters
There are several styles of girdles for the oil pickup tube, where it connects to the oil pump, and those seem to be a good idea. Plus, they are cheap insurance.
The bushing on the shifter cable decided to take a dump today. Ground was scorching hot but I was able to limp it home using a small bungee cord I was able to buy at a U-Haul down the street
this will work, I recommend also adding a washer and cotter pin for a permanent fix, I just drilled a small hole in the nipplle for the cotter pin and it's been good for like 4yrs+ now
SpareParts
North Idaho
Again another day of not doing anything to Cracker but collecting parts.
Was up at the wrecking yard today and got some real floor mats, but they are tan so i need to dye them black after i clean them.
I also picked up these power running boards. Said they were working when the Escalade was put in the yard.
SpareParts
North Idaho
Also got THIS ordered today for the power running boards.
Really torn on ordering the wire harness for $175 bucks or making my own. Should be easy to make im sure and all i would need to order is the plug and pins.
HERE is the video that pushed me over the edge from thinking about it, to doing it. Controller new off eBay was $40 and steps were $50.
For that price, it's worth it to give this a go.
Runfor5
Northern VA
Good ~3 hours of work today: got the front cover off + P-side exhaust manifold. Moving onto the front diff drop -> oil pan removal phase next. I don’t see how you remove the oil pump without dropping the oil pan.
I’ll take heads off once I can get 30min no interruptions from kids. Continuing to ignore that rem. nut on D-side manifold lol.
j91z28d1
struggling to decide what fuel pump to order. on rock auto oem for 300$ but doesn't come with the level sensor and float, they have DENSO for cheap has everything and Bosch I see some say the oem one had a Bosch sticker on, but I've had horrible luck with everything Bosch I've ever used.
ugh, I hate changing parts before they break because all new parts are junk these days but stuck on the side of the road a 1000 miles from home towing wouldn't be good either.
blah. half tempted to just replace the pump in the hanger only from a good source like deatschWerks or Aeromotive.
Have you looked at Herko? @Doubeleive seems to like their offerings:
jkhuntzinger
