Very Poor Gas Mileage
AmunRoo
Chicago
Not sure if this post is in the right place. I recently purchased a 2010 Escalade with the L94. My Long Term fuel Trims are near perfect and they fluctuate between -2 and +2. I have only had the truck about a week and half. I have ordered new O2 sensors, both upstream and downstream. A new MAP sensor. A new MAF sensor. A new PCV hose and a cold air intake. I also have a 2007 Yukon Denali that is getting better gas mileage. Also seems like it takes less money to fill the tank on the Escalade. Maybe there is an issue with the floater or the tank itself. If anyone has had similar issues or any ideas of something I may have missed, i'd greatly appreciate any input. Also buying new plugs and wires. Possibly headers while i'm at it lol
I don't know what to tell you my average is around 9.6 no matter what (gm) I drive
you can expect mpg to increase comparatively to how much you ease up on the big pedal
my wife can drive the same vehicles and get 13+ I taught her to drive but she still doesn't go as beast mode as I do.
I have found that for me it doesn't matter the vehicle, it's just HOW I drive.
you could drive yours and get 17 and then I could get behind the wheel of yours and get 9.6
unless it's detectably running like garbage then things like a bad cat can cause a noticeable drop in mpg which you can sort of determine by the temperature of the cat
you could also maybe look at things like the torque converter.
Marky Dissod
At the very end, you mentioned headers ...
'Funny' thing is, I very strongly suspect you have a leak somewhere between the MAF and the O2 sensors.
Most likely, an exhaust manifold leak. Less likely but still possible, an intake manifold leak.
These leaks would normally show up as LTFT's off by more than +2 or -2, though.
You can try switching your MAF sensors between vehicles, see what happens ...
A few years ago we had a fella join up after he bought a new 6.2 Tahoe. He immediately complained about the poor gas mileage. Turns out the fella lived in downtown Miami and the truck rarely got out of the city or even past 35 mph. All that stop and go in the city had him at around 9 mpgs or so.
I finally convinced him to take a Sunday drive to Belle Glade for a hamburger and then he realized that his truck got good mileage once it was able to stretch its legs and run at a constant speed.
mikez71
I'm at 8.7 mpg, use lots of E85, slightly quicker than traffic, all city, 5.3, 3.08..
I probably need to check tire pressure..
He mentioned one costs more to fill..
Is the tank filling up all the way? (fuel guage full?)
Or, like he said, the level sensor is off, reading empty before it actually is?
You've got a lot of good answers above on gas mileage. 70% of it is not controllable (weight, motor, gearing, actual roads/traffic and speeds driven), but the other 30% is quite controllable, and as @Doubeleive stated, it is almost exclusively in how you manage your gas pedal.
Regarding the less money to fill the 2010 Escalade versus the 2007 Denali, the 2010 Escalade has a 26 gallon gas tank, and the 2007 Denali has a 31 gallon gas tank.
AmunRoo
AmunRoo
Chicago
A lot of great responses. Thank you all very much. I appreciate it. So to answer some of the questions, I drive the trucks exactly the same. My foot is just as heavy on the Denali as it is in the Escalade. The displacement between both trucks is the same. Only difference is that Yukon has the l92 and the Escalade has the l94 with AFM. I was under the assumption that I would have better gas mileage since it automatically switches between four and eight cylinders but I guess that's all just hokum and fairy tales LOL as far as calculating gas mileage, I wasn't running off what the dummy screen tells me. I'm basing all of this on distance traveled and how much the needle moves on the gas gauge. As an example, I live in Illinois and a round trip to Kankakee from Chicago is pretty close to 140 miles. The Escalade left me at a quarter tank while the Denali will only run about half a tank. I have the short body Denali not the XL so I do have a 26 gallon tank in each truck. At least I think I do. I need to do a physical inspection on the Escalade. Once I'm down to about an eighth of a tank, it only fills up with about 15 to 16 gallons which does lead me to believe that there is an issue with the floater. I am changing all the sensors because the truck is new to me but it does have 121,000 miles and it is 14 years old. I don't know when the sensors were last changed and I figured a refresh won't hurt. I just installed and cold air intake and all the sensors are on order. I do plan to replace the stock muffler with a Magnaflow straight through bullet muffler and remove the cats. The headers I'm going to replace because the current factory manifolds are rusted beyond belief. I don't think I have any leaks as I'm not throwing any lean codes. I think I'm going to do a smoke test and see what I get out of it. I did notice that the oil filler neck is pretty loose and it might be a source of air intrusion. I do understand that these trucks are heavy and it's also a big displacement V8. I do a lot of long distance driving so my fuel mileage should be better in the Escalade. That's just an assumption and a poor one at Best LOL I'm going to drive around for a few days with the new Cai and see how it does. I'll post updates. Again thank you all for the responses.
Also, the Denali has full exhaust, no cats, headers, c a i, high flow water pump, all aluminum three row radiator. So it runs cooler and has a more free-flowing exhaust.
Marky Dissod
I'm at 8.7MpG, use lots of E85, slightly quicker than traffic, all city, 5.3L, 3.08.
No, you need 3.73. Note how the 8L90 & 10L80 have even more assertive gearing than the 6L80 for getting underway.
10L80 x 3.23: ... 15.15 ... 9.66 ... 6.95 ... 5.72 ... 4.91 ... 4.13 ... 3.231 ... 2.75 ... 2.23 ... 2.07 (7.32 Spread)
8L90E x 3.23: ... 14.73 ... 9.60 .... 6.72 .... 5.46 . . . . . . . 4.10 ... 3.231 ... 2.75 . . . . . . . 2.10 (7.01 Spread)
6L90E x 3.08: . . . . . 12.41 . . . . 7.28 . . . . . . . . . 4.72 . . . . 3.55 . . . . . . . 2.625 . . . . . . 2.05 (6.01 Spread)
6L90E x 3.73: ... 15.03 . . . . 8.82 . . . . . . 5.71 . . . . . . 4.30 . . . . 3.18 . . . . . . 2.49 (6.01 Spread)
If your use case had enough highway mileage, one might recommend 3.42.
Marky Dissod
Yukon has the L92 and the Escalade has the L94 with AFM.
but I guess that's all just hokum and fairy tales LOL as far as calculating gas mileage.
Engine Half@$$ was made primarily to benefit GM during their Corporate Average Fuel Economy testing.
On a brand new vehicle, sure, this is worth 2 or 3 highway MpG.
Bet if they did this testing after 100,000 miles, they'd find the MpG benefit fades over time.
And this is all before the two mode lifters quit.
You may want to look into at least disabling the Engine Half@$$ featurebug.
An ecm / tcm tune would likely get back the MpGs, plus make it more fun to drive.
Once I'm down to about an eighth of a tank, it only fills up with about 15 to 16 gallons,
More likely an issue with the Evaporative Canister Purge system.
Do either of your vehicles 'fart' - push out vapors - when you unscrew the cap?
AmunRoo
AmunRoo
Chicago
No farting! They are both proper ladies lmao
I did however notice that the AC compressor is constantly cycling even though I'm not running AC. I'm going to turn off HVAC completely and see if it's still cycling.
wjburken
Eastern Iowa
How many miles does it take you to get down to 1/8 of a tank in your Escalade? What does that equate to for miles per gallon when you fill it up with 15-16 gallons? How does this compare to your Yukon?
Before you buy anymore parts, do this one simple thing because it sounds like it until now you’ve been mainly operating under guesses and assumptions instead of actual diagnostics.
So, you are measuring/estimating fuel consumption based upon the 'position' of your gas gauge? If yes, that could be contributing to your issue, as these gas gauges are not linear across their bandwidth, and each individual gauge may vary some others. I recommend, if you have not already done so, measure your fuel consumption based upon how much gas you put into the truck until the first automatic gas pump click-off and the actual miles driven.
6spd 2012 yukon xl 6.2l 3.42 awd (average 9.6mpg) *even after extended highway driving for hours without stopping
6spd 2018 silverado crew cab long bed 5.3l 3.08 4X4 (average 9.5mpg)
6spd 2016 suburban 5.3l 3.08 2wd (average 9.5mpg)
explain that one to me lol
I know why-my big ass foot!
4spd got about the same in my 2000 yukon xl 5.3l 3.42 4x4
4spd got about the same in my 2003 silverado 5.3l 3.72 2wd extended cab, long bed
4spd and about the same in a couple other 2wd suburbans 5.3l 2004,2005
my wife loves to comment on it about how she brought mine up to 13 and I made her's go down :driver:
one would think the different weight and axles ratios, engine size, etc would make one better or worse than the other but NOPE
when I went to the 6.2l, from a 5.3l I was kinda scared I was going to get like 8, but that never happened. I mean I can make it happen but that's a workout.
AmunRoo
AmunRoo
Chicago
My current average
wjburken
Eastern Iowa
My current average
When was the last time you reset that?
You still need to do the old school calculation as the dash uses information from the sending unit. If the sending unit is off, the dash calculation can be off.
Fill tank (stop at first click of pump), note starting mileage on odometer, drive until you need to refill, note ending mileage on odometer, fill tank (stop at first click of pump), note gallons pumped, divide miles traveled by gallons pumped.
AmunRoo
AmunRoo
Chicago
I'm definitely going to try and remember to do the manual calculations for the gas mileage lol
I just bought new rims and tires. Running 24s now
dizhai
