Does any use a Fumoto oil pan drain valve?
Rayyy
Northern California
Yeah, all my BMWs have had top mount filters, and the manual references a vacuum hose down the dipstick tube to remove the old oil.
I had actually purchased a fluid evacuator specifically for my 540i, but UPS delivered it to the wrong address, and those dicks kept it. I got a refund after filing a UPS claim, but shortly after my car was totalled in a rearend collision.
I have another 540i, and might get another fluid evacuator just to make life easier.
Which 540i? Legendary E39?
St. Louis
I have the EZ Oil Drain valve on the 2012. They're nickle plated and use an o-ring. I also have the 90* hose adapter that attaches to the output.
To put one on the 2001 it would need the extention adapter so it will fit in the pan recess.
I too use a punch and poke a hole in the filter and let it drain before removing. Been doing that since 2007. If I'm in a hurry and don't want to sit and let the filter drain, I've found that a SOLO cup slid over the filter while loosening catches most of the mess
Charlie207
Charlie207
LFOD, New Hampshire
Yes, the only version worth owning. I'm on my third one now. Top was sold in TX, middle was wrecked by some skinny-jean hipster in a Duramax, bottom one is current project.
Charlie207
Charlie207
LFOD, New Hampshire
Nice! The latest one is a true M-Sport? 6spd?
Here is mine. View attachment 395254
I think it's just a clone, and I suppose I should run the VIN to see what's up, but it does have a Dinan intake and exhaust.
It's a 2001, so not a true M-Sport.
All my BMWs (4) and Saabs (7) have had manual gearboxes except that one Saab 9-5 Aero.... Sold that and bought a 5-spd Xterra.
the_tool_man
Upstate South Carolina
I've been using a Fumoto for years. It does drain more slowly than without the valve. But I just go do something else while it drains. I just moved to a new house where the wind always seems to blow. I'll need to get a piece of hose for future oil changes so the oil doesn't blow all over the place. I, too, punch the filter and let it drain. It doesn't eliminate the mess. But it helps quite a lot.
EddieC
Dos the projection of the threaded portion cause dirty oil to stay in the pan when draining?
the_tool_man
Mercedes' OEM oil change procedure involves vacuuming the oil out from the top. I wonder how much they are able to exchange that way.
It's hard to say. But I'd speculate the difference is insignificant, or they wouldn't recommend it. If you think about it, some amount remains clinging to every surface inside the engine. You can't get it all.
BlaineBug
Clown World
Yes I know. The only way to be sure would be to remove the oil pan and see how much is "trapped" behind the fumoto threads.
opfor2
Riverside County, CA
I would love to install this on my 2011 but I'm concerned for I actually use my SSV for what it's designed to do and that's going off-road. Is the Fumoto valve strong enough to withstand the rigors of 4X4ing?
Charlie207
Charlie207
LFOD, New Hampshire
Do you normally strike your oil pan drain plug?
EddieC
I have a ValvOMax on two vehicles and love them. No more mess on my hands from turning out the drain plug.
I was wary of the Fumoto but the ValvOMax has a double seal; the check valve ball is the primary seal but the dust cap has a seal in it and functions as the secondary seal in the event that the ball leaks. That sold me.
Hodmjstone
