Plastic Engine Cover
diezelraccoon
Had an issue removing the plastic cover on the top of the engine that says Vortec. The 8mm bolt that holds it down just spins and won’t come out. I did manage to get the cover off but had to tear apart the rubber bushing under the bolt. I’ve tried a couple different methods, but the bolt will not come out of the plastic pillar. I’ve seen a couple different threads on this, but can’t really seem to find an answer.
Is the plastic pillar it screws into replaceable?
BattleTank
Senior Member
To be BRUTALLY honest. I always take my engine covers off and toss them. They retain heat, get in the way and just have ZERO functionality on an engine. Especially when you need to replace the oil pressure sensor.
Your call if you want to reinstall it.
D
diezelraccoon
That doesn’t really answer my question
Donal
Americus Georgia
Is the plastic pillar it screws into replaceable?View attachment 431922
I believe the tower is glued in place and not considered replaceable and not available. the metal insert can be removed with a puller, but finding a replacement may be another problem. The bore of the tower is already damaged by the insert rotating, as the cap screw is turned to remove and will be damaged more when the insert is pulled out. You may consider living with the condition until you have to service the engine and then replace the entire unit. In the mean time, rotate the hex and see if the insert is rotating the the tower or the if the screw is rotating in the insert. Adding a trickle of crazy glue to the joint may be enough to remove the screw. Be aware the hole in the tower will be damaged and may require a glue in or oversize replacement.
Wait, is this a different tower that I remember. Bring in the the data, and history of this vehicle.
Matthew Jeschke
Sahuarita, Arizona
You can get a helicoil and rethread it. Take one of the other bolts (they are same size) go to hardware store and use the bolt size tool by loose fasteners in store and figure out thread size. Then go to eBay and order helicoil kit.
Or maybe some here knows the size of that bolt and its thread pitch?
I got rid of all my covers, including fancy ones on my vette. Just saying they serve no purpose other than if you are entering a car show.
Sparksalot
Bastrop County, Texas
I pulled the cover on thecopcar when I added a catch can, never reinstalled it. I haven’t pulled it off thethirdtwin yet though.
Mudsport96
40.923,-89.488. Illinois
If the insert is spinning in the manifold, you could carefully try squeezing the plastic with vicegrips and then try turning the bolt. But at this point there is chance (albeit a small chance) that you could break the manifold plastic. Even could crack it down to a runner. Then you would have to replace the intake anyway. Your call.
if it is stipped out then you need to apply upward pressure from under the bolt while using a high speed electric tool like a drill with a socket attached. then it should come right out
so maybe some large curved pliers with a socket under them so you can apply pressure while spinning it out.
unless that thing is totaly fubar I could have it out seconds
and if the metal insert is spinning as already mentioned then you need to apply both upward & downward pressure which could be done with the curved pliers and some kind of metal clip on the bottom of the pliers that fits around the bolt so when pressure is applied it holds the insert a little bit and gives you upward pressure at the same time.
I have taken worse things apart because I tend to strip bolts out, nothing is ever tight "enough" lol
S33k3r
Dallas, Texas
With those engine covers being useless, why did GM include them? Seems like they could have saved a ton of money if they left them off.
I'm thinking they serve some purpose; could be sound dampening, could be heat dissipation so the hood paint doesn't die sooner. Of course I am just guessing.
Ultimately, we know GM is cheap, and would not spend the money if there weren't some reason.
BattleTank
Senior Member
Cosmetics sells. Nobody wants to see all the mess of wires/hoses/pipes etc under a hood.
15burban
Wisconsin
If you can hear the difference "sound deadening" from sitting inside the vehicle you've got some darn good hearing.
Fwiw ram quit putting their engine cover on a few years ago so I've read and seen.
adventurenali92
Big Bear Lake, ca
I’m in the crew of “that’s what was on my engine before I touched it, so it needs to be put back together exactly as it was before I disassembled it” mindset. I managed to break the passenger side cover on the corner where the rear bolt goes through today when i went to put new spark plugs in…… and i over tightened the forward 10mm nut on the drivers side cover and cracked it….. now I gotta go junkyard hunting for those parts cuz it’ll annoy me that they’re broken and not right….. lol
S33k3r
Dallas, Texas
I
want to see it.
And I am nowhere near alone.
How do we really know you aren't sitting in your mother's basement, logging in here just to troll us?
(The same way you know I'm not sitting in my mother's basement logging in just to troll you, of course!)
Drewphil
