I've posted on here before with a dc clamp meter my mechman pushing over 200amp's with everything on and my aftermarket amp running.
that was with everything on that can you possibly turn on+ amp and subsi
one could monitor dc amps with a external clamp like this one to meter that can read it, you just run extra leads to inside the vehicle
$27 on amazon
Geotrash
Dave
Richmond, VA
$27 on amazon
I do have a clamp meter so will try that next time everything is hooked up.
j91z28d1
huh. I guess I just expected it to read current at all times. mine being overly complicated BS shows the current of everything all the time haha.
oh well, external clamp it is.
Geotrash
Dave
Richmond, VA
Got the new idler pulley on today and it solved the binding and noise I was hearing. Funny thing is the bearing on the old one felt okay when I was turning it by hand but it was definitely the problem. The new one was made in Canada.
I also installed an ICT Billet oil cooler block off plate on the ‘07. Hopefully that solves my oil leak problem. I drove it for a half hour or so and it seems to no longer be leaking. Time will tell.
St. Louis
Does the '07 not have an oil cooler?
mikez71
Been "tuning" my 2012 6l80. Swapping maps back and forth driving about a week now..
Have tried '15 tahoe and '18 silverado settings. The '15+ shift schedule is better, other than earlier 0-20% throttle 2-3 shift. (about 1mph, can notice!)
(2018 probably the same, but I don't have a file with 3.08 gears)
More important is the shift feel. (because I have NO IDEA how to tune that!)
Doing just the shift scheduling and torque adder maps, doesn't really change the shift feel.
But after 'updating' transition times, inertia tables, oncoming/offgoing preset pressures, and desired output torque factor, the shift feels better to me..
Flatter more level feeling shifts, and I used to commonly get a 2-3 rear end clunk when letting of throttle, that -seems- reduced or gone.
The '18 silverado tune seemed a little crisper, but I figure I better stick with the '15 tahoe tune.
(the '18 tune had desired output torque factor zero'd for 1-2 and 2-3 shifts, and transition times little faster than the '15.)
I thought it was in my head, but after swappping back and forth a few times, I'm feeling good about running the new settings..
...other than 1-2 and 5-6 volume changes (about 1/2 of original number) so I wonder if they threw in an extra clutch or changed something else..
I did run one tune with updated volumes, and it seemed to run OK, but have since been running stock volume settings...
For some reason my Output shaft speed does not show up in VCM scanner (hptuners) but does show up on Tech2..
Anyone else using hptuners?
Geotrash
Dave
Richmond, VA
Nope. The factory radiator didn't have the engine oil cooler built in either - only the trans cooler. Apparently it only became standard on later model year Denali's. I installed a new radiator last year that has both coolers, so next time I replace the motor mounts, I'll install engine oil cooler lines, too.
the_tool_man
Upstate South Carolina
I changed my oil and emptied the catch can last night. I used my new HF ramps, which worked great. Last change I sprayed off the underside with brake cleaner because it was covered with oil. I was hoping to spot the leak this time. It appears to be coming from the driver side engine block, not the rear main as I'd feared. I guess that's the oil cooler. How much fun will that be (mine's AWD)?
Also, the high-beam switch in the left column stalk is getting intermittent. I can flip it forward to keep the brights on. But the pull-back-to-flash, which I use ALL THE TIME because people are slow, doesn't really work. I guess I wore it out. Is it possible to get in there to clean the switch? Or, should I just buy a new one? They aren't very expensive. But I only want to do it once.
t_bergman
Chicago
Since it's the steering column and that uses plastic components that I don't want to break or have to also replace, if it were me I'd buy the switch brand new and then call it a day.
Geotrash
Dave
Richmond, VA
I just did mine yesterday on my ‘07 but mine has the block off plate instead of cooler lines - also AWD. The job is a lot easier with a 10mm flex-head ratcheting combination wrench. Watch the torque value on install. You definitely don’t want to have to put a helicoil in there. I had to in my 2012 and it sucked.
Drove it to my gf's apartment and parked next to her Durango. Durango is supposedly a mid-size but it looks barely any smaller than my Tahoe. Narrower, for sure:
Used it to sweep the dust off the curb:
Wednesday evening, I downloaded the Speedometer app since my speedo only goes to 120. Then tested it:
mountie
Remember.... Stock tire treads are rated at certain speeds... But not for an extended amount of time. The damage may not show for a while.... factory treads are attached to the casing with heat, so heat will also loosed some of the adhesive.
( On the highway... when you see a tire tread.... most are from factory tires.)
Retreads are attached to the casing with a "cold-bond" adhesive, and fewer separate.
( Sometimes, the retread will separate a bit at the edges from the casing, but mostly limited to that)
Driving a Bugatti at about 260 mph... No worry about over-heating the tires..... It runs out of gas before the tires get too hot ! :cool:
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
the_tool_man
Yeah, that makes sense. RA didn't have OEM, so I ordered one from a dealer. Paid a little more, but I only want to dig into it once.
Good point. I had to look it up- My Pirellis are rated to a maximum sustained 149MPH.
Interesting about the cold-versus-hot-bonded retreads.
Wow.
Merch619
