just reading this site and the threads about pellets in the evap system. grabbed a oem one off rock auto and put it on. figured worth the money to avoid the hassle later. since these trucks all seem to follow the same failure trends.
I still have the old one. I think I'll swap it in and see if I just got a bad one. looks like a oem one, it is my luck thou haha. I'll make sure I didn't mess up an o ring too. the 2 small hoses came off easy. the big one I fought with a bit, so that's why I replaced the rear vent valve with oem too. thinking I probably cracked something.. blah.
on a side note. anyone know off the top of their head if the oem spare tire has a pressure sensor valve stem in it? I'm about to mount up a tire on a new spare rim and got to wondering. can't find anything on Google besides some cars do and some don't. if not, how does the truck react when you put a spare on it and the tire sensor reads the flat still in the back of the truck?
I know the c6's lose their mind without pressure sensor readings. go into limp mode and won't drive but like 40mph or something. guys take the tire sensors, put them in a pvc pipe capped off. fill it with 35psi and throw it in the back of the car as a work around.
