Proper DoD delete oil pump
j91z28d1
I didn't see your exact combo, so I just looked up a 2011 xl with a 6.2. this is what the manual says.
minimum hot pressure
6psi at 1000rpm
18psi at 2000rpm
24 psi at 4000rpm
no way I'm pulling a awd oil pan and front cover to replace a oil pump on my truck till it's the minimum or at least close to it.
oh the afm valve is just to limit max psi to between 55 and 75psi.
03GMCYukonXL
03GMCYukonXL
Thanks guys. I feel better. My eninge is a 5.3 non vvt. Cam was a non dod/afm cam that can be used eith both vvt and non vvt. I'll send it I guess. Worst case scenario, I get a new short block lol. I have 172,*** miles.
randeez
south florida
no reason why pressure shouldve gone down.
i would start with the sensor, maybe throw the old one back in or mech gauge and see.
i wouldve plugged the towers, 10 bux worth of plugs for the piece of mind.
did you pull the oil pump to change the timing chain or anything?
the cam being for vvt or not i've never heard of unless you just mean youd need to install the lock out block in the actuator, did you use a single bolt cam gear? 3 bolt? actuator with the block? im wondering if it has the oil passage for the vvt actuator that would need to be "plugged" if not used? the path for oil to the actuator is a groove in the forward most race of the cam iirc
the pressure relief in the pan, unless engine was very sludged up i wouldnt worry about it being stuck open
03GMCYukonXL
03GMCYukonXL
The cam I got said it could be used with or without vvt. I do not have vvt in my truck. I did change the timing gear and tensioner. It was a single bolt cam. I will still probably plug the holes in the near future. It's not too hard to get to.
Geotrash
Dave
Richmond, VA
So I did the DoD delete and fixed all my post DoD delete issues except for I'm geting really low oil pressure. I did replace the sensor AND the screen with a brand new one. But I'm getting like 10 PSI or less at idle and about 35 PSI while driving. Maybe 40 PSI when I get on it.
I'm not sure if it's really that low as I don't really hear any lifter noises at idle, however I've read more than a few times that I need to get the melling 10296 pump. Which sucks because I just put the thing back together and have been driving it lol. I really don't like dropping the front diff just go get the stinking oil pan off just to get the pump out. Anyways, does this forum agree with the recommended pump change?
I'm a little late weighing in on this one but the EXACT same thing happened to me when I reused the original oil pump after my dod delete on my 2012. Granted it's an aluminum block, but since the original pump was high volume, I don't know why I ended up with lower oil pressure than I started with by 10 PSI across the board. Only thing I can figure is that the o-ring I used on the pickup tube was either nicked or slightly undersized. But when I went back in with a new Melling high volume pump and o-ring, I got my pressure back.
03GMCYukonXL
03GMCYukonXL
Thanks for all the replies. I've been driving it everywhere with no issues. When I get the time and motivations I'll swap over to a higher pressure pump. But as of now, it's all good.
Foggy
KS
Just as FYI
When I did my dod delete and heads work , I did not have time to remove the pan so
I'm still on my orig pump . My oil pressure did not change at all. I did use the proper valley plate
and used the O rings to seal the dod ports.
RET423
Just as FYI
Exactly, I have never seen a compelling reason to remove the factory DOD pump; it is the best factory pump ever put in the LS series engines. In fact the TSB from GM on the pan pressure relief valve is just as ridiculous, the DOD engines use oil because of the V4 mode; it has nothing to do with oil spray from the relief valve.
j91z28d1
I'd be interested to hear how oil gets from the dod hardware to inside the cyl to burn?
Marky Dissod
What are the two shortest oil paths to inside the cylinder?
I have a somewhat unique experience with this.
I actually had my former '12 Yukon XL ecm reprogrammed to INCREASE the engine half@$$ duty cycle,
over and above GM's original limits.
Including but not limited to being more eager to activate engine half@$$ mode, more often and more quickly.
At the time I was trying to get better MpGs by using engine half@$$ mode 'as much as possible'.
After a while, the engine started consuming oil.
In hindsight, he 'lazier' cylinders were glazed, something to do with carboned / coked piston rings.
Credit @B-train with that observation.
Marky Dissod
what is the shortest path for oil inside the cyl?
1. From the oilpan past three piston rings. Short, but not easy - unless the piston rings are worn.
2. Over the top of heads, down the valve stems. Not short, not easy - unless the valve guides are worn out.
#1 happens more often, and sooner, than #2.
RET423
By leaving both valves closed under cylinder deactivation the disabled cylinders have trapped air which cushions the pistons and helps the engine feel smooth when in 4 cylinder mode.
The engine is designed to lubricate the cylinder from beneath and control the oil to a limited amount via the oil control rings and the expanding gasses on the power stroke.
With no power stroke the oil passes the oil control ring but is not burned (no power stroke) but does receive cool pressure from the trapped air in cylinder.
This causes coking of the oil control rings and huge mess in the combustion chamber, when the cylinder is reactivated it cannot completely burn that coking off. Over time this causes the oil control rings on the DOD cylinders to become loaded up and lose their ability to effectively control the cylinder lubrication; the result is increased oil consumption.
j91z28d1
Possible theory I guess, but I think they only choke up the one cyl that the bypass valve sprays excess oil into to all the time? and the drivers side is always worse than the passenger side.
leading most to think it's the pvc system that is pretty awful, more so than the valves being closed. my catch can gets quite a bit of oil and it's new enough to have the upgraded valve cover and the deflector. valve cover is just a bad place to suck air from. the valley is much better spot.
I have had a compression gauge on a cyl with both rockers off (non ls) before and believe me. it does nothing.. gauge doesn't even flicker and the 2nd ring is always cut on a angle to scrap the wall down of anything the oil ring misses.
I feel like it's a horrible pvc system using oil and gunking up rings thru the intake portsmore than the afm. before my catch can I had my intake off and was amazed the amount of oil that drained from it. there's guys here with 200k on afm still working without issue. unless they have some magic oil, they would have coked up the rings a long time before that.
just my 2 cents on it. could be wrong..
RET423
Put a bore scope in the AFM cylinders and the non AFM cylinders and you will see the difference, insufficient PCV oil mist can cause this as well (why catch cans became a thing) but a catch can will cure that issue with the PCV entirely; the DOD system will coke up either way. And that oil psi bypass is below the windage tray, it is not creating an issue in any cylinder.
Also, the DOD system activates after the intake stroke on the cam base circle, this is done intentionally by GM to provide that air cushion; it is designed to do that. Just running a compression test on an engine with both valves disabled has no air to compress.
j91z28d1
if there's air in the cyl, wouldn't that keep postive pressure, opposite of sucking oil up thru the rings?
I'll have to take your word for it. I have a nice bore scope but I'm not going to pull fresh plugs just to look at the cyl haha. honestly I think they would look fine thou, I ha oem plugs in mine when I got it at 135k of active afm, also the hybrids run in 4cyl mode much more often because of the electric assist. it doesn't need to switch to v8 to get moving. especially interstate cruise, it can handle the small elevation changes by battery not switching out of 4cyl. from the settings I see in hp tuners under dod, looks to be limited mostly by time to oil foaming. but anyways, point being all 8 plugs looked the same, no extra white crude on the afm cyl from burning extra oil.
the windage tray has a nice cut out right at the bypass valve.
to be fair, I alway thought the bypass valve sprayed oil straight up out of the hole on the top on the back cyl wall. but this Pic it looks like there's some holes around the bottom. so I don't know for sure. so eh? my truck has a crazy high oil pressure variable displacement pump. like 60 plus almost all the time. so I have a feeling it's bypassing constantly, especially with afm turned off. no sign of choked up rings or low compression to me.
I mean I get it, it's a junk system. but the details just feel off to me.
RET423
The engine I am hoping to pull apart for a delete this weekend has the worse coking in the cylinders I have ever seen in my bore scope but all of the plugs look great, GM coil packs are awesome.
Towmaster
