89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Found a good pic of the mystery spoon/paddle.
Geotrash
Dave
Richmond, VA
Checked the battery voltage this afternoon (haven't driven it today at all) and it's at 11.74V now but the temp is a good 25 degrees warmer than yesterday so... inconclusive. I also unplugged all of the vampires in the power sockets last night.
Down8
Which radio did you get? Have a link?
X2, I'm already liking the power/volume/tune buttons.
This is the one I got:
www.amazon.com/dp/B0CM2SRCVD
I also grabbed this camera ($10):
www.amazon.com/dp/B0B7LM1B68
But had to get some power/RCA extensions b/c it is meant for a car, not a large SUV. Therefore I haven't installed the camera, yet.
This is the one I wanted (literally twice the price):
www.amazon.com/dp/B09HCG6ZR6/
I had to find the code to get into factory settings (000000) to turn down the amp a little (75%) so level 1 isn't still a bit loud. I am also working on how to change the steering wheel controls, as they don't work exactly like I expect. Otherwise, I've been able to find and change whatever I needed/wanted to. [RSE doesn't yet work, but I know I'll need an adapter to get that working.]
-bZj
that's a chunk lower than I would be comfortable with, I think most autoparts storeS could load test it for you in the parking lot
Fubar0715
Scott
Southern New Hampshire
that's a chunk lower than I would be comfortable with, I think most autoparts stored could load test it for you in the parking lot
FWIW, my voltage was slightly (11.9v) higher than what you saw and I choose to replace the battery. In my case, starting was sluggish and REAL SLUGGISH in cold weather. I travel too often and leave my truck while out of town so didnt want to come home to a surprise wait for roadside after flying/traveling most of the day.
Geotrash
Dave
Richmond, VA
FWIW, my voltage was slightly (11.9v) higher than what you saw and I choose to replace the battery. In my case, starting was sluggish and REAL SLUGGISH in cold weather. I travel too often and leave my truck while out of town so didnt want to come home to a surprise wait for roadside and flying/traveling most of the day.
Thanks gents. Good call. I’ll put in on a proper charge overnight and see where we land through the week with it.
Geotrash
Dave
Richmond, VA
It’s alive!!! Today’s work on the LR2 (sorry, meant to post this on the what you up to thread in the lounge) was the intake manifold, remaining cooling system hoses, PS fluid reservoir, pax side motor mount, new radiator and all new fluids. Spent about 3 hours on it today in total. It really is a great runner - satisfying to get it all back together, too.
GM trucks aren’t the only ones whose motor mounts wear out:
And check the debris in the old PS fluid reservoir:
Pretty quiet for recording on a phone. Usually they sound like they're coming apart!
Hodmjstone
