How noticeable is E85 vs. 87, or E85 vs. 93 octane? It's not available anywhere in my state, and I'm curious about how many furious ponies I'm missing out on.
IIRC, GM rates the Gen4 5.3 at +11HP/13TQ on E85.
Yeah, not noticeable.IIRC, GM rates the Gen4 5.3 at +11HP/13TQ on E85.
time for boost.
I think having a stand alone battery pack powering an electric blower for WOT scenarios makes total sense.you laugh but I literally follow a electric supercharger message board lol.. guy has run 9s in a Ford LTD off one. things make crazy power per pound of boost because it's not run off the engine or restrict the exhaust.
the tech is catching up.
Out of curiosity, is there a replacement VLOM (valley lifter oil manifold) gasket, or does the entire part need to be replaced?
I'm still in "oil leak investigation" mode, and figure since I just replaced the intake manifold gaskets, and had it all apart, I should think about replacing the other parts .... Now that it's all back together.
I can't believe you left that VLOM in there. Did you at least snug up the loose bolts? See the red circles in this picture? They are some of the rivets that hold the solenoid carriage to the cover. The gasket is sandwiched between them. You will not be able to replace that gasket. Will need a new complete assembly.
I just follow along, but it would be cool, since I've got all the batteries and inverters already on the truck, I could tie into whats there, and if I could make say 3 to 4 lbs of boost, without any downsides, be kinda cool.
but I tell myself, I have enough projects, it's the wife's mini van. I need to leave it alone haha.
Is there a table or graph that would compute what 4psi added to a stock engine would add in terms of HP/TQ? There's already a 2nd battery tray in the engine bay.
Plans?Just scored this 08 ESV today for $2800. Has a pretty good oil leak up high on the passenger side but other than that there’s nothing wrong with itView attachment 406702View attachment 406703View attachment 406704
Plans?
eventually, I kept telling myself I would do it when I had a certain amount of money saved up and went past that and still hesitant to spend the money, maybe when cruela passes away I might get a little windfall. Takes me too long to save money to turn around and drop a *** on something unnecessary.time for boost.
Awesome deal! That's the 6.2 right?Just scored this 08 ESV today for $2800. Has a pretty good oil leak up high on the passenger side but other than that there’s nothing wrong with itView attachment 406702View attachment 406703View attachment 406704
Yup 6.2. No dod either on the early 6.2’sAwesome deal! That's the 6.2 right?
