Rebuilding the rear diff, (8.6")
Seems that 14-19 inch pounds of pinion preload is what's documented, and there's a few articles showing 15-30.
I can't tell if that's a revised figure, or maybe pinion with carrier preload.
It's all back together and I had 18 inch pounds of pinion, and about 25-27 ish total of pinion and carrier with the 3.42 ratio so all should be in spec.
There are specs for a new preload and one for after seal replacement which is about 3-5 pound higher.
wjburken
Eastern Iowa
did you do them? or had them done? what was the cost?
I did not. Needed it done sooner than I could. Had the local dealer do passenger side lifters and an engine mount and total was $1800 for all of it.
UPDATE:
Got the vehicle back from Rotman's in Maquoketa, IA on Saturday. Final bill for passenger side lifters and associated consumables and gaskets, along with replacing the driver's side motor mount, taxes and shop supplies was just under $1800.00. That also included a free loaner car to use while it was in the shop.
I just asked for pics.
Pics he sent were of both spoilers, but they were covered in dust. He says the paint is great. I'm gonna have to go see them in person. I'll wash 'em off to get the real story on the paint. One has a chunk missing from the red lens and the other looks like it might have a star crack. At the least, they're candidates for the Eagle Eyes light conversion. I'll have to negotiate the price after seeing them personally.
mikeyss
Longmont, Colorado.
What did I do to my GMT900 today (well on Tuesday)... Got it towed away for a transmission rebuild. I missed the call from the shop today, but it seems the pump and torque converter are the cause of failure, but they didn't say where all the fluid was pouring out. I had a circle d converter in it, so I'm anxious to see what happened to it when I speak to them tomorrow. Estimate is looking like $7k plus, but this is considering the HD parts going back inside it.
Geotrash
Dave
Richmond, VA
Bummer. I’ll also be interested to hear what you find with the converter.
is that the beverly hills shop? holy crap, had mine rebuilt for 500hp and all the fixes it was $4000 w/100k 3yr warranty, maybe I got good deal.....
I even made it perfeclty clear I intended to boost it, so I wanted it built right
the_tool_man
Upstate South Carolina
When my OEM stock (BB tuned) tranny failed earlier this year, I was in the middle of moving and needed my Yukon back ASAP. My only viable option was to install a GM-built HD transmission, as the local dealer had one in stock and couldn't get a non-HD one for weeks. That was $4200. By the time I paid labor, replaced the radiator (for trans cooler) and cooler lines, and change the fluid in the TC and diffs, it was about $6k total.
m1dn
Truck has been running rough on cold start for about a minute or less for a while now, didn’t pay much attention to it.
Now yesterday it got rougher and didn’t go away, then got bad in drive around 1-1.2k rpm.
Finally engine light popped up for few seconds and i was able to read it as cylinder 2 misfire.
Swapped wires, still cylinder 2.
Spark plugs are less than a year old, maybe 10k miles tops, NGK TR5.
Took out the plug and it looked fine, clean!
Replaced single plug with NGK TR5IX, runs smooth again and no rough idle on cold.
Never seen a single plug go bad!
Also got a top engine cleaner just in case, might run it over the weekend
the_tool_man
Man, I'd be sweating if that had happened to me. I read over and over about a misfire code being indicative of a lifter failure! I'm glad it was just a plug. Why NGK and not ACDelco? I'm asking because I just swapped mine and went with OEM.
Geotrash
Dave
Richmond, VA
It's possible that the plug got dropped somewhere along the way, which can lead to micro-cracks in the insulator. When that happens, they will start misfiring eventually.
m1dn
No OEM in Canadian Tire, didn’t want to wait tbh
mikeyss
Longmont, Colorado.
How long ago was this? In today's economy, everything seems to cost way more, lol
I feel the pricing for mine is on point, I am getting a billet reinforced rear planet, billet 4-5-6 hub, 6 pinion input planet, new billet converter, new steels and clutches, brand new bell housing and pump, etc.
Hodmjstone
