All this wiper arm talk reminds me. I tried to take off my driver's side arm. I took the nut off but the arm is frozen to the stud. I need to find a small puller to grab it off or something.
Did you stand the arm in the up position so you can use it as leverage? ( close the hood first) I’ve never had luck with the arm in the down position.
I was gonna suggest this. Stand it out straight and rock it up and down while pulling and pushing like you're trying to stab it through the windshield. Be sure to mark the wiper to the splined stud before you remove it so you can put it back in the same position. Or, if you're replacing it, mark the glass with a Sharpie on some painter's tape under the wiper blade.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Believe me I tried that method. I was afraid of breaking the linkage. That sucker is on there TIGHT.
Geoffsfas10
St. Louis
Drove mine about 2000 miles down to the Gulf Coast and back, then gave it a nice wash yesterday to get bugs and mud off the exterior, and vacuumed all the sand and road trip snack crumbs from the interior. Tahoe did good, first time driving it that far since the DoD delete, averaged just under 21 mpg at 75 mph over the trip.
Charlie207
LFOD, New Hampshire
Installed the Dorman manifold clamp, due to broken stud on the end. A little tight, but no dramas.
The other side will be my nemesis, up there with those stupid ATF cooler lines.
j91z28d1
I wish someone made a bolt on fixture that centered a short reverse drill bit. with some good penetrating oil I bet 90% of these would screw right out.
or like one of those body shop stud welders that tacks the nail looking thing onto body panels and then a slide hammer is used to pull the metal but to the bolt and then they twist out.
Charlie207
LFOD, New Hampshire
Just have to be able to access the studs straight on. I have so many head-shields and sound deadening that it almost seems like you'd have to pull the engine to get proper access.
wjburken
Eastern Iowa
St. Louis
Weld the inside of a nut to the broken stud.
If the stud is recessed too far below the surface of the manifold flange, use a piece of copper tubing to keep the weld from sticking to the sides of the hole in the manifold flange. Weld won't stick to copper, and build up the bolt with weld metal, then weld the nut over the top.
Or just unbolt the manifold from the head.
mikez71
received Melling water pump. Pump looks ok so far as i can tell, no weep hole visible (maybe its hidden by pulley?)
thermostat neck looks a little porous. Hoping stock one will look good and I wont have to use this new one. Also included a motorad thermostat. Are they good to go?
Geotrash
Dave
Richmond, VA
receive Melling water pump. Pump looks ok so far as i can tell, no weep hole visible (maybe its hidden by pulley?)
Yup. Always had good luck with melling and motorad stuff.
Geotrash
Dave
Richmond, VA
Drove my ‘07 600 miles to Nashville for a company event. Looking at flights, I would’ve spent the same amount of time between connections, layovers, security, and Uber rides. And I enjoy driving very much after nearly 2 million miles on the airlines over the last 20 years. Popped my Buc-ee’s cherry, too!
Charlie207
LFOD, New Hampshire
My buddy in TX, who makes decent money in the ISP sector, showed me two job postings for a Buc-ee's 20 miles from his house:
1st was $125k per year for the car wash manager, and 2nd was $250k/year for the general manager. He's thinking about applying for both.
schafer98
