05 Tahoe EBCM
ScottyBoy
Shreveport, La
I repaired my EBCM about 3 years ago. Pretty much right before the pandemic started. I took plenty pics and I was going to do a write up, but my phone crashed shortly afterwards and I lost ALL the pics. I suspect it had something to do with my wife repeatedly dousing it with Lysol. Regardless, I did remove it with a T27 I believe, T25 had a bit of wiggle and I was scared I would strip them out. Thankfully I didn't strip any screws. I did however strip one of the T5 (or was it T7) screws that you unscrew to actually open up the EBCM to repair it. After removing all the screws, you slowly cut the seam/rubber sealant all around it with a very sharp razor blade all while SLOWLY prying it open. After I got it open, I reflowed the solder on each of the relays and every solenoid. Then I sealed it back together with RTV, put the screws back in, and re-installed it in my truck. Not one single ABS light or code ever since.
I feel bad because I took a LOT of pics, from everything to removing it, to the fastener size, to cutting it open, reflowing the solder, then putting all together again. I felt it was pointless to do a write up with no pictures. Also, I do have an "L" shaped module, but which version, I'd be lying if I told you.
JPVortex
JPVortex
Feeling with the T25 I tried on mine, they feel so round that they dont even feel like a torx at all anymore. Not sure which shape I have, but once it's off I plan on finding one with the exact number whether its online or at a junkyard in person.
JPVortex
JPVortex
I'd be interested to hear about how to saw it off though without damaging it lol. I'm also going to try removing the mounting bracket bolts and seeing if I can fit one of those extractor bits in there. They always seem to break on me though when trying to use them.
May also use a dremel with a small cut off wheel to try to cut slits to get a flathead in there.
Try a t27 like @ScottyBoy said. I have had luck with stripped torx by using a slightly bigger torx and tapping the tip in with a small hammer, then using a magnetic screwdriver or 1/4” ratchet and turning carefully. You need to have support behind whatever you’re working on so it can’t bounce while you tap the tip in.
JPVortex
JPVortex
I dont think mine was even a T25 though, it may have been a T20 iirc.
to cut the module off it's not repairable but it does save you from having to pull the pump out.
you would need to take a saw and basically cut the module in 1/2, then extract the remainder of the 4 screws
if you can get just the 4 bolts cut then you can pull it out, the rear ones are the tricky part
JPVortex
JPVortex
So pretty much making room for the extractor to get the 4 torx out? did you cut it in half so 1/2 of it fell off? And its a horizontal cut across im guessing?
there is no room where the module is to do much of anything other than fit your fingers in there
JPVortex
JPVortex
I wonder if disconnecting 3 three bracket to frame bolts will allow more play to move it a bit. I'd like to be able to return this one for a core, which some private companies will take for like $10 off.
all you can do is try, it might squirrel around a bit when trying to cut if it is not secured
S33k3r
Dallas, Texas
So you don't use an Android phone? Those typically backup pictures to Google photos...
S33k3r
Dallas, Texas
Dumb question but... Well, that has never stopped me before (even when it should have)...
When you get a stripped screw/bolt like that, have you ever considered taking a spare screw/bolt you have laying around, gluing it to the bad screw/bolt, letting it set, and then unscrewing in that manner?
ScottyBoy
Shreveport, La
Yes, but I specifically had it set to NOT backup up to the cloud/Google Photos. Let's just say, I had some "spicy" photos I took and I did NOT want them anywhere but on my phone. I forgot to change the settings back after that and it bit me in the ass. I lost a LOT of pictures.
JPVortex
JPVortex
I feel like glue or epoxy like jb weld would just break right off tbh.
JPVortex
JPVortex
well that's being brutally honest no shame from here though lol!
S33k3r
Dallas, Texas
Which pictures that you lost upset you the most? :cool: No, not looking for an answer; we know it was the spicy 'Hoe pictures -- right? :laughing1:
nonickatall
Germany
Were for sure hot toe pictures.
You know toe, camber and caster pics.. :Big Laugh:
JPVortex
JPVortex
Got the EBCM off with a combination of sawzall, cutoff wheel and a dremel tool. Things totally mangled lol. No damage whatsoever to the pump at all.
Studs still need taken off but dont think that'll be too much of a pain.
The part number on it is totally faded, but it's an 11-2-2 model, so its readily available everywhere on ebay. Nervous to get a used one because it might have problems too.
I dont think I'll need to pair it with my VIN? Should be plug and play.
This was a total PIA to get off but I'm glad its finally off even though its mangled so bad.
AZPatriot1963
