03 Yukon Denali manual swap...maybe?
97SLeeper
Hey all I got an 03 Denali I had since army days. Its been across the country several times an once out. Sitting at 325k miles an so far 2 trans rebuilds. And I think another one is on the way. 2022 I bought a 17 Denali and kept the 03 for work until some kids in a rental totaled the 17. Lookin for a 2020 or new one but been debating working on the 03. It would be fun to have it manual trans an thinking a 6 speed with maybe an adapter plate to the awd transfer case. Im not worried about a check engine light if thats the only problem but I feel its a bit more complicated than that. Hell if this works maybe a lil 6.2 swap will follow. I see the tahoe an escalade guys doing it so im hoping this got a chance. Anybody with expirience on these trans feel free to hype me up or shoot me down lol
rockola1971
Indiana (formerly IL)
Need to know what donor vehicle you intend to get the manual out of?
And the ? I seem to have to ask around alot lately is......why? Just why?
97SLeeper
The donor would depend on what fits. Im seeing the NV trans are being used, but why not a T56? The ? Is I love manual trans its just that simple
MassHoe04
Western MA
How about a nice Tremec 6 speed!
But, you may be limited to rear wheel drive...
Mudsport96
40.923,-89.488. Illinois
I agree a manual swap would be fun, but short of a few adapters i think the 3500 5 speed is going to be the easiest to do. And the reason I personally would do that is the availability of off the shelf parts from any truck that would have come with that transmission.
Alex_M
You'll probably want to have the ECM tune changed over to manual and that should take care of any potential engine control issues.
Blackcar
New venture 3500 probably easiest I would imagine floor stamping has place that could be punched out for shifter.They made different bell housings for which ever engine it was going to be married with and several different tail housings for two-wheel drive or four-wheel drive etc. I would think that console would need to be removed and a bench seat might work well.
Also, would have to get clutch pedal setup for hydraulic clutch and neutral safety switch. Need a donor vehicle that meets engine drive train of your 03. 03 GM pickup truck would work best.
rockola1971
Also, would have to get clutch pedal setup for hydraulic clutch and neutral safety switch. Need a doner vehicle that meets engine drive train of your 03. 03 GM pickup truck would work best.
Whatchu talkin' about willis? All LS based engines have the same bellhousing. 4.8, 5.3, 6.0, 6.2
Blackcar
I guess I missed the part where anyone was saying anything about dodge truck engine or transmission being used. Im not even gonna comment on the v6.....
Since I suggested OP look at the 3500 was just suggesting watch when and if OP went that direction to be carefully with bell housing. Since it was used in other vehicles and brands. Which is why my suggestion on donor vehicle.
Which makes your replies to my post nonsense.
std03sub
If I remember correctly, The awd transfer cases use a 5-bolt pattern unlike the 6-bolt pattern on 4wd transfer cases, This will be the biggest issue with trying to use stock transmissions and transfer cases. -UPDATE: Appears it is a 6 bolt flange so that isnt an issue, Im guessing the problem is the input spline count wouldnt match? You should be able to disassemble and swap input to fit 32 spline manual output shaft.
I did an nv3500 manual transmission swap on my 2003 Suburban 4wd. Got rid of the 246 A4WD and replaced it with a 241C from behind a 4L80E since it has the same output spline as NV3500/4500. Did no tuning im happy with how it runs sometimes it high idles when coming to a rolling stop in neutral but slows down after a second at 0kmh
03catburban
Georgia
NV3500 swap is easy. Have any questions I'll try my best to answer.
03suberban
Im looking at doing a nv4500 swap on my 03 yukon denali 1500. I'm wondering what parts I'd need to accomplish that?
X-ray Nerd
