how to remove whats left of o2 sensor?
after they decided they needed the OEM cats more than i did, this is the rear driver side that i was left with. tried "everything" to get it out.......i need some help! this is what i was left with
KC 2013 Tahoe
Chandler, Arizona
Heat and torque.
Looks like you have enough room on the shoulder of the old sensor to get a pipe wrench (aka: monkey wrench) around it. You can also slip a pipe over the handle of the wrench to get even more torque... BUT before you torque away, heat the surrounding pipe with a propane torch to help the pipe expand, then torque away with the pipe wrench. If you don't have one, Harbor Freight has them for a great price: https://www.harborfreight.com/18-in-steel-pipe-wrench-61350.html
If that doesn't work, I'd weld a larger hardened bolt to it (5/8 or bigger), then use a breaker bar and hardened socket to twist it out. Or simply weld an old spare 1/2" drive socket to it and go again with the breaker bar. It should pop loose and be pretty easy to remove from there.
Kevin
never seen a 02 sensor that had a allen wrench fitting, drill it most of the way out then use a bolt extractor, no sense in making it harder then it needs to be
X-ray Nerd
