6.2l DOD Delete parts list
E
Enoob
Looking for the next steps, so do I go with the oil pump and button up the front, or go with heads first?
E
Enoob
Does someone have the torque sequence and specs for the heads on this 2011 6/2? Can't seem to find them anywhere.
Geotrash
Dave
Richmond, VA
Tighten the M11 cylinder head bolts (1-10) a first pass in sequence to 30 Nm (22 lb ft).
Tighten the M11 cylinder head bolts (1-10) a second pass in sequence to 90 degrees using J 45059.
Tighten the M11 cylinder head bolts (1-10) a final pass to 70 degrees using J 45059.
Tighten the M8 cylinder head bolts (11-15) to 30 Nm (22 lb ft). Begin with the center bolt (11) and alternating side-to-side, work outward tightening all of the bolts.
E
Enoob
Thanks Dave. That worked well. What process did you use for the rockers if you can share? Not seeing a good site/video for a novice like me.
Dustin Jackson
@Enoob Get the Chilton it has all of this info in it. For the rockers its was the most complicated torque sequence IMO. I installed my heads, then buttoned up the oil pan, then buttoned up the front, then did the rocker arms and valve covers. Sorry looks like you were asking a while ago about some of that
Geotrash
Dave
Richmond, VA
Getchaself a subscription to alldata.com. It's reasonably priced for DIYers and has everything you need for everything for these trucks - especially troubleshooting guides.
E
Enoob
OK - finally got things back together. Ready to power up and am not sure exactly the next step with the tune. I was able to connect the Autocal V3 to the vehicle and obtained the OEM tune, which I'm trying to save to my PC. Since I changed out the cam, I believe I need to also upload a file to the vehicle before I attempt to start (whic I understand is preloaded on my Auvtocal. Those that have done this, is that correct? Not finding exactly how to do that part yet, but still looking for the steps. Any quick guidance?
Geotrash
Dave
Richmond, VA
Did you send your stock tune files to Blackbear along with the specs for your new cam to get a startup tune file back from them? If not, that’s the next step.
they will then send you a tune that will get you up and running. Then you go through the data logging process to gather the data they need for the final tune.
E
Enoob
ok - Was a little confused as I thought they were sending it with a basic tune, but now I get how it works. I was able to pull the transmission and engine tune off and sent that to them. Not sure their turnaround time, but eager to try and fire this thing up.
Geotrash
Dave
Richmond, VA
Gotcha. Unfortunately, it can be as much as 2 weeks but they will prioritize you if they know you’re down and waiting on a startup tune.
E
Enoob
It took about a week to get the initial tune back. Added them and was able to start it up. No engine lights and oil pressure came right up. Had to run to the parts store to get a plastic "t" for the heater coolant line (if that is what you call it) as the internal o-ring was bad. While there, the guy on the phone was talking to someone with a collapsed lifter. Now I can say been there done that. I will need to get my readings to get a final tune, but so far so good. I'll post a video of it running when I can figure that out. Thanks to all on here who have posted the info that I needed to do this and answered questions. Much appreciated.
rdezs
Curious how this turned out for the op. I'm getting ready to do the exact same thing, and there's also sent the smaller camshaft.... which I returned and purchased the l9h factory stock camshaft. I've already deleted the AFM DOD with a Diablo tuner, am I correct in assuming the l9h camshaft is so close the computer won't know the difference? I'm also debating on the tensioner that the l94 has versus the LS2 dampener. Seems to be pros and cons either way with all kinds of opinions. Considering this is my wife's grocery getter and she never revs it up, I'm leaning towards the factory L94 tensioner. Unless of course I get in there and find it in pieces. Coming up on 160,000 miles and have not lost a lifter yet, so this is preventative. It just got accelerated due to either a rear main or rear cover oil drip. I will also be retaining VVT, plugging the oil relief in the pan and changing to a Melling 10296 pump with the + 10 psi spring installed. Upgrading to rocker Trends but otherwise completely stock.
kikeap
