Just Fishing
Can't fix stupid
Utah
Yeah, I had the both lines the make up the assembly completely detached from both ends and all supporting brackets.
There was simply not enough room to move the lines fire/aft enough to grant enough free slack to get the front hard line out.
I did a different sort of setup for my tahoe.
hardest part was that I moved the OEM cooler forward from where it was.
challenges there for sure. :jester:
I fought the oem lines for a bit, and that was part of my idea to just keep part of it and then rock my secondary run for the -8an full flow cooler.
I was able to do some snipping since I was converting to -6an, then adapting it to flow back into the -8an lines.
There is an option there.
but if you already have the replacement lines....
If you don't then they will convert directly to -6an
just use stainless or steel fittings + the tube flares support for them.
Expensive, but AN is really easy to deal with later down the road.
Charlie207
LFOD, New Hampshire
It just would have made 1000x more sense to route the lines under the welded-in tubular cross member instead of routing them through the skinny gap above the cross member.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Success!!!!!!!!!
St. Louis
Does that line have a section between the radiator and front of engine that's rubber hose?
The clean and shiny stuff in the pic. Regular split loom like what was on there from the factory. I don't know if it's made up of the same material. But it looks, feels and smells "normal" and not like the typical Chineseum plasticy rubber stuff that aromatizes Hazard Fraught. I considered doing the woven stuff. But it's too damned hot to be getting that involved. I'll replace what's missing and dry rotted and close the hood.
I hear ya. We are in the middle of a 3-day mini heat wave ourselves up here, it hit over 100 today but starting Tuesday we will be back in the low 80’s. Our entire spring it was raining and in the 60’s, I missed all those sunny and 70’s days we usually get. It went straight to hot on the first day of summer. I was attempting to dress up some of the hoses in my engine bay but the heat put a stop to that. I quit after replacing one hose on my new overflow tank with some braided I had laying around.
I hear ya. We are in the middle of a 3-day mini heat wave ourselves up here, it hit over 100 today but starting Tuesday we will be back in the low 80’s. Our entire spring it was raining and in the 60’s, I missed all those sunny and 70’s days we usually get. It went straight to hot on the first day of summer. I was attempting to dress up some of the hoses in my engine bay but the heat put a stop to that. I quit after replacing one hose on my new overflow tank with some braided I had laying around.View attachment 373891
Oh, now you're just showing off. lol
It has hit 100° a few times this week. Was 100° today then we had a bad storm blow through that brought pea-sized hail. It's hot enough to bake cookies on your dash, but then ICE falls from the sky o_O
Drwinlied
Right rear has leaked for a while now. Last time it was in the shop the guy said they cleaned tf put of the wheel to get it to hold air.
That worked for about 4 days and tire was slowly losing pressure again. Said f it and bought a new wheel. Was tough to buy just one oem and not do a full fun replacement...
Shop guy calls when putting new wheel on, "yeah so the wheel is fine...there is another nail in your tire" lol
Apparently I was a bit quick to blame the wheel. That makes 2 plugs in that tire...idk if u guys are OK with that but I get slightly uneasy driving around with 2 plugs in a tire.
So...point...put a new wheel on and plugged another hole.
took her on a 420 miles round trip up thru ebbetts pass (8730ft) then down and back up to monitor pass (8314ft) then thru the high desert and back thru kit carson pass (8652ft) to get fireworks, I think i need to put the trucool back down under the lower bumper trans only hit 192 but coolant temp went up to 230 several times, ambient was high nothing lower than 77 deg with some snow in the shadows still
and used the trailer grade braking a lot that's a nice feature I think the BB tune gives it a sporty feel.
spotted a eagle grabbing some road kill off the highway and avoiding getting hit by oncoming traffic, lol looked like maybe it was a skunk not sure
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
Meh, two plugs is no big deal. I have only ever had a plug fail once in my life. Never had one blow out, ever.
Charlie207
LFOD, New Hampshire
Yes, there is a section of flexible rubber hose, but it won't provide enough slack/stretch to allow the end of the hardline to fit out of the hole. I assume I need to remove the bolted-in crossmember near the back of the engine.
Probably have some free time in a month or so.
That’s wild.
Drewphil
