I see a di*k and balls :)
According to your positive response to the Rorschach test in Post #38,912, we can surmise one or all of the following:
1) You likely do not have problems with your relationship to the opposite sex.
2) You may not be sexually frustrated.
3) You may have phallíc fascinations or common homoeroticism
4) You have a generally healthy séxual mentality as your responses as such are not absent but are infrequent. Comparatively, if they were as frequent as @Dantheman1540's, this can be deduced as a form of schizophrenia.
Qualifying references:
Some psychologists believe that séxual feelings and interpretations are unconsciously present all time (Freud). Therefore it is wise to say something positive about blots, resembling a penís, vagína or bréasts. For example, a red blob can resemble the female génitals, but one does not want to say wishing not to over-score the séxual responses. In this case, it is better to say that it resembles a butterfly than to say it looks like a crab, as butterfly are a more positive response. A not positive response to such potentially séxual motives may indicate some problems with the relationship with the opposite sex.
Left: An ink blot reminiscent of a female genitalia, orchid or microscopic aquatic animal.
Right: An inkblot reminiscent of two seahorses kissing each other.
If the test person has too few séxual responses, it may indicate séxual frustration.
Traditionally, there are five response details that have often been associated with homosexuality. Namely that the test taker tells that he sees: 1) buttocks and ănus, 2) feminine clothes, 3) male and female genitalis, 4) human figures without male or female features, 5) human figures with both male and female features.
A large number of séxual responses will indicate schizophrenia. However, a total absence of séxual interpretations will also be unusual, at least if the applicant is a man. It is said that men think about sex up to 50 times every day.
pwtr02ss
Tennessee
3) You may have ******* fascinations or common homoeroticism
4) You have a generally healthy ****** mentality as your responses as such are not absent but are infrequent. Comparatively, if they were as frequent as @Dantheman1540's, this can be deduced as a form of schizophrenia.
Some psychologists believe that ****** feelings and interpretations are unconsciously present all time (Freud). Therefore it is wise to say something positive about blots, resembling a *****, ****** or *******. For example, a red blob can resemble the female ********, but one does not want to say wishing not to over-score the ****** responses. In this case, it is better to say that it resembles a butterfly than to say it looks like a crab, as butterfly are a more positive response. A not positive response to such potentially ****** motives may indicate some problems with the relationship with the opposite sex.
View attachment 369383View attachment 369384
If the test person has too few ****** responses, it may indicate ****** frustration.
Traditionally, there are five response details that have often been associated with homosexuality. Namely that the test taker tells that he sees: 1) buttocks and ****, 2) feminine clothes, 3) male and female ********, 4) human figures without male or female features, 5) human figures with both male and female features.
A large number of ****** responses will indicate schizophrenia. However, a total absence of ****** interpretations will also be unusual, at least if the applicant is a man. It is said that men think about sex up to 50 times every day.
And here I just thought @Dantheman1540 had roped him in...
Sounds right. I understand how resistors make heat. I was just surprised they would make a lot of heat in a flasher circuit. I guess it's 50% duty so sitting at a light for a few minutes would add up.
ya testing one in my Yukon for a few minutes to figure out how to get it to work right resulted in it burning the living hell out of me in a split second if I touched it little bastards get as hot as a catalytic converter seems like anyway.
RooTBeeRthe1st
I might have spoken too soon.
The resistors I got have separate for the running like and the signal wires...the bcm no longer hyperflashes, but now I don't think my turn signals are working.
Have to investigate when I get home from the river.
Quark
Atomic Nuclei
What if I see seahorses holding up a Trump doll?
avalonandl
Troy, MICH & Naples, FL
Larry The cable guy stopped by and looked at my screen
Rorsach my A$$....
I dont see no Female Stuff, I see a guy with messy hands.....Washin them in the sink....
juicedgsr95
North Carolina
Share your tips/tricks. I have one to install when I do my radiator & cooler lines.
I had to take the driver wheel liner out, had to remove the bolt holding on the auto ride sensor and the bolt holding on a bracket next to it. Also need to remove the heat shield from the exhaust manifold (2 of the 5 in mine broke off so I didnt put the heat shield back on) All the bolts will have to be accessed from above, you'll need swivels and patience. Once they are loose I was able to run them out mostly by hand. I jacked up the motor from the primary cat on the drivers side. Then with some force and patience you have to move the hard lines a little to squeeze the mount out/in through the wheel well.
This is the video that finally help me.
Good luck, it will test you haha.
Charlie207
LFOD, New Hampshire
The hardlines for the engine oil cooler are being replaced at the same time, so I can just cut those away.
Thanks for the video, and tip of jacking up with the cat. I'm up in NH, and assume every nut and bolt will be rusted.
the_tool_man
Upstate South Carolina
There's probably a dozen ways to do the DS mount. Here's my method. It only took 2 hours. I did have a buddy help me reach a couple of the bolts, which saved time. Mine's AWD, too, which adds to the fun.
Here's my favorite video on how to do the swap. There is no single vid that duplicates what I did exactly. This guy jacked the engine up from below with a homemade piece, whereas I used an engine hoist.
Kee Fuller
las vegas
Any of you guys know where i can find a generic version of this clip? The back plastic trim on the headliner close to the tailgate is hanging due to this broken clip. GM wants 5 bucks for 1 clip and i know i can get a pack of 30 for 5 bucks.
GM part number
11561654​
wjburken
Eastern Iowa
RooTBeeRthe1st
75%E
Zeroed before my 20mi commute this morning, still hit some stop and go and rolling 20ish mph for about 5mi on i10. Topped out around 65 for a tad.
Also have a small leak on my AN line I made for the ethanol sensor... So I need to tighten that fitting up, or replace that section of hose.
Escalade2007
