Dan's ratty truck
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
Also noticed that when I installed the leafs years ago I put the bolts in wrong and the end of the bolts have been rubbing the hanger for idk 5 years. I guess I should fix that now the bed is off.
Got a whole lot done today! Starting by finishing up welding a few things that were too ugly to let slide. Then I wheeled the axle down the hill across the pasture to the shop to clean it up with the grinder and slap some black on it. This one pint of Chassis saver painted the axle and a bunch of the frame of the Silverado. I love this paint it’s easy and just works incredibly well.
Then it dried while I got a slab of ribs, came back and rolled it up the hill under the truck bolted it in and set the truck down in its own 4 feet for the first time in a long time!
Could have just bolted a dil*o in place of the u-joint, sat on it and rode that mother down the hill. Might have made some others here jealous though. That’s a whole different type of spin class. :shrug:
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
Lmao! I need to pull the shaft because it’s not gonna work anyway and needs to be used as a length checker since it’s the right length but needs a different yoke and I want a beefy shaft like the Tahoe has. I need to come up with a drive shaft loop as well.
pwtr02ss
Tennessee
Needs a beefy shaft...don't we all :sigh:
That paint looks really good. I'm assuming it's a brush on product? I did base/clear on my c10. Laid it on with factory peel and buffed some of the areas slick that you could see. After 10 years, it's starting to show its age. I wish I would've done chassis black and been done (or powder coat). That would've saved me a shit load of work
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
Brush in and there’s nothing really nice about this paint other than you can apply it to rough rust and it makes stuff black forever. It does fade a little over time to a dull black but as long as it’s black and not rust IDC. I like the brush on better than spray too because no worry of overspray and brushing it is satisfying. I wish my powder guy would get an oven big enough for a frame but I don’t want to strip the truck that far down anyway lol.
I just used Por 15. Seemed ok, just gotta wear gloves--I didn't. Also brushes on.
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
I’ve always wanted to try POR15 but I’ve had such good luck with chassis saver I don’t see what could be any better and it’s usually a couple dollars cheaper on Amazon.
I’ve always wanted to take CS, POR, Rustoleum, east wood, and maybe another couple Paint over rust products and test them on small pieces of rusty diamond plate. Let them cure a solid week and then torture test them with hammers and brushes to see which is best. But that requires a lot of time.
I never had any luck with Rustoleum. Used it on the hitch, didn't do much. I used the Por 15 on the lower door sills on the Hoe, and ALOT on the lower parts of the van and front bumper. I bought the cleaner and degreaser, but didn't use it.
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
I never buy any of the prep products either, I just dust off the loose stuff and brush it one as thick as possible.
Todd kinda has you covered:
Somewhat related:
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
Somewhat related:
Cool, so POR15 wins but I think Chassis saver is even better so Chassis Saver wins in my independent nonbias virtual review :bleh:.
But seriously cool video, I could punch myself for cleaning the axle overly well because I could tell while applying the paint that it wasn't going to stick as well as it did on the rusty frame. I think it will be good enough tho, I will likely touch up with $.99 cans of black from wall mart or just let the dirt cake on.
I like Todd’s videos. The one on penetrants settled my curiosity and led me to keep on using WD-40 not just because it works as well as any other but because of the fact it has other uses as well. Those videos make me glad I don’t have to deal with rust although if I did I would be applying POR-15. There’s so much snake oil out there in the rust business it’s crazy. Encapsulates rust my a**.
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
More painting and taking stock of parts I need. Didn’t realize the hitch was so rusted, I towed a lot of heavy and I’ll distributed loads with this piece of Swiss cheese.
Laying on my back in the dirt to paint the undersides of the frame was fun.
Dantheman1540
Dantheman1540
Sugar Loaf Mountain
Got the brakes on but still need to plumb the rear, can’t find the old SS lines so I guess I have to go bin diving tomorrow.
HeavyHoe03
