6L80 Sonnax ZIP Kit, Pressure Switch rebuild, remote filter install, and fluid flush in 2013 Escalade ESV (Pic heavy)
skpyle
skpyle
Senior Member
Dude, you're awesome! Thanks for posting all of this. Excellent write up. Very detailed and very informative. Thanks again. I'll have some questions for you when the time comes:)
You are very welcome!!!
The transmission valve body work is done, but the saga is far from over...
This thread still has a ways to go.
skpyle
skpyle
Senior Member
Soooo...my next step was to have been to install the remote spin on filter assembly for the transmission fluid.
However...it was 8:00PM, I still had to put fluid in the transmission, and pull the Escalade down off the ramps. It needed to be ready for a flatbed at 9:00AM the next morning. And I needed sleep.
I did just that. It took a little over 6.5qts of Dexron VI to fill the transmission to the middle of the HOT zone with the trans at 122 degrees idling. I first filled it to the COLD mark on the dipstick. Then ran the shifter through all the gear positions, pausing for a few seconds in each. Had everything done and cleaned up by 10:00PM. The transmission pulled and moved the Escalade from the turnaround spot up to the driveway with no issues. However, I did not move fast enough to let it shift out of 1st gear.
9:00AM the next morning, local wrecker service flatbed appeared and we were off to a local transmission shop.
Why? you might ask? Because the Sonnax ZIP kit instructions and the service manual told me to.
In the Sonnax ZIP kit instructions, it states: Fast Learn Adapts, Following installation of the ZIP kit, the Service Fast Learn Adapts procedure must be performed. Follow instruction on the scan tool, or reference OE specifications for details on the procedure.
In the service manual, it states:
Note: The Service Fast Learn Adapts procedure must be performed when one of the following repairs have been made to the vehicle. Failure to perform the procedure after one of the following repairs may result in poor transmission performance, as well as transmission DTCs being set:
  • Transmission internal service/overhaul
  • Valve body repair or replacement
  • Control solenoid valve assembly replacement
  • TCM software/calibration update
  • Any service in response to a shift quality concern
Also, from what I have read, driving the vehicle and letting the transmission could likely result in codes being set, as the transmission is still using learned adaptive parameters from before the repair. I didn't want that, so off to the shop it went.
Like I have said before, which is where it went wrong. I am an idiot, past and present tense. In my head, since this was a scan tool procedure, I would be in and out. I rode with the driver in the cab of the flatbed, and stayed with my Escalade. The shop took my information and keys, and told me they would call when it was done. Say what?
They said it would be done around 4:40-5ish. It was 9:45AM. Oh. And, it never occurred to me that there would be other jobs in line before mine. Like I said, I am an idiot.
To compound this, I was trying to get too much done. Returning from the P0131/P0171 fiasco at the Hendrick Cadillac of Monroe NC service department, an 18-wheeler tossed a rock. Which cracked the windshield. Safelite AutoGlass was scheduled to replace the windshield at 1:00PM this same day. So, I screwed up. Again.
I sheepishly called SafeLite and rescheduled.
And then started walking.
I live in Blacksburg SC, out in the country. The transmission shop is in Gaffney SC, approximately 10 miles away. My wife was at work. Anybody I really knew was at work. So, being GOOD AND PI$$ED at myself, I started walking. Eventually, I was able to get my mother in law on the phone and she picked me up. Only ended up walking 2 miles. It was good for me. Because I am an idiot.
The transmission shop called around 4:00PM, said my Escalade was ready. They said they performed the relearns and took it for a road test. The transmission shifted through all the gears and performed well. Except the technician noticed it was slipping in 3rd gear.
Huh?
My first thought was, "what did I do wrong?" My mother in law gave me a ride to the transmission shop. There, I asked the same question, and they told me, based upon the description of the work I performed, nothing I did could cause 3rd gear to slip. They said it was likely the 3-5 drum was cracked.
Lovely. Just lovely.
Pretty much all I could do was drive it until it quits. They of course offered to fix the transmission for me. I politely declined. I still have the 2 year powertrain warranty from Hendrick on this Escalade...
On the drive home, I didn't notice anything different. I couldn't feel any slipping. Which tells me this transmission was doing it before I bought the vehicle. I paid attention to the shifting when I test drove the Escalade. It felt the same on the drive home from the transmission shop as it did on the test drive.
The next day, I drove the Escalade 7 hours total to and from Hendrick Cadillac in Cary NC for a wasted trip to get the paint touched up on the front and rear bumpers. The transmission performed just fine. Shifted fine. I beat on it some on the highway. Temps always looked good. I saw 154 degrees at 75mph, and 165 degrees at 85mph. (I like to drive fast, and I was on I-85S in NC. Don't judge me...)
I ended up in a stop-and-go traffic jam, and saw the transmission temp go to 185 while crawling along. Once I got back up to highway speeds, the temp dropped back down in the low 160's.
Once I got off my exit, I performed an experiment. I put the shifter in M, and toggled it to 2. I drove up my road. Once 2nd gear was wound out sufficiently, I toggled the shifter to 3. I waited with bated breath, and felt the transmission immediately shift into 3rd gear. No flaring of RPM on the tachometer, no slowing of the vehicle. I toggled the shifter into 4 and drove to my house.
I am not sure what to make of this. I have driven my Escalade daily since that day. I have felt nothing amiss in the transmission. I don't necessarily think the transmission shop was trying to scam me, as they come well recommended. I think it is more I can't feel what the technician was feeling.
Regardless, all I can do is drive it. Because, if I invoke the warranty now, I will probably get laughed out. I would assume the transmission would have to be actively screwing up for them to be able to troubleshoot and diagnose anything.
Geotrash
Dave
Richmond, VA
Huh?
Send it! You would be able to tell if it was slipping significantly.
skpyle
skpyle
Senior Member
Something odd I noticed on the drive to and from Cary NC. Before the transmission shop performed the relearn, the Instantaneous Fuel Economy page on the DIC never read anything. It always said “0 MPG” and nothing more.
After the transmission shop performed the relearn, the Instantaneous Fuel Economy page showed MPG values and V4 status.
I was surprised to see this on the display. I was crusing steady state on the highway.
I gave it some gas and the display changed.
I am not sure what to make of this. Does it mean AFM had been disabled? I thought a special tune or kit had to be purchased for that. Did the relearn ‘reset’ this?
I do know that I am preparing to put a Black Bear tune in it. I have purchased the AutoCal V3 package and am almost ready to datalog. I just have to clean the MAF and throttle body. But, I need to wait for the clone Tech 2 I ordered to arrive so I can do the throttle body relearn procedure.
Point is I am going to have AFM disabled with the Black Bear tune.
Huh?
Shoulda, Woulda, Coulda, the Tech-2 would have paid for itself and save you the tow, shop time, walking, cancelled appointments, etc.
The slippage the technician experienced was because of the Adapts being run and the transmission relearning. It goes away after the first few stop and goes. You'll do it again after the installing the BlackBear tune, let him know you have the capability of running it.
skpyle
skpyle
Senior Member
Yeah...I saw that coming. I ordered a clone Tech 2 on October 14th. In fact, it showed up last night before I left for work. I thought about that, but...I had that week off of work for vacation. I wanted to get the transmission work done then and out of the way.
Regardless, you are correct, I could have done it better.
Very good to know about the slippage and the relearn. I will tell Black Bear when I submit the data logs.
Thanks!!!
George B
¯\_(ツ)_/¯
Oconomowoc, Wisconsin 53066
What does the relearn have to do with the tune from BBP? I never discussed a relearn with them but I have the ability to do it. Whats the difference?
St. Louis
I have the same question as George B.
I've installed tunes with my Diablo Intune I3 and have done the TCM to firm up shifts a bit and remove torque management but have never done a trans adapts relearn with the Tech2
BlackBear also tunes the transmission and when Justin was tuning the truck with me, an in person tune, he did the Adapts while we were driving. Well, I think we either pulled over or he did it at a red light before it turned green. Guess he likes the transmission to get a fresh start but I no longer remember exactly what he said.
George B
¯\_(ツ)_/¯
I asked because they didn’t say anything about adapts with my email tune so I just load and go.
Well, maybe he does something else that warrants it when tuning in person or maybe he doesn't mention it because most folks don't have a Tech-2 and would balk at the additional expense of having the dealer do it? Might consider asking him and letting him you have a Tech-2 and can do it if necessary.
St. Louis
So would it hurt anything to do it if it actually doesn't need it?
skpyle
skpyle
Senior Member
Upon returning home from the wasted trip to the dealership for 'paint touchup', I got to work on installing the remote spin on transmission filter. I am big fan of these, and have them on all of my automatic transmission vehicles. Spin on filter gets changed yearly, pan filter every 5 years. It also makes fluid flushes easier.
I put the Escalade up on jack stands at the front to give me room to work underneath.
Had to remove this air deflector at the front. I am not used to seeing one of these.
Under the front end, looking up at the new transmission cooling lines from the transmission to the radiator and from the external cooler back to the transmission.
My intent was to install the remote filter mount here on the inside passenger front frame rail, tucked up out of the way, yet still easily accessible.
Check it out, I didn't know my Escalade still had tow hooks. Granted, they are behind the front fascia.
Also a view of the new oil cooler lines.
skpyle
skpyle
Senior Member
Parts needed for this conversion: WIX 51515 oil filter (NAPA Gold 1515 also works), B&M V1A transmission oil filter, well used remote filter mount and hardware, 3/8" OD metal fuel line bent for this application, Derale 3/8" ID transmission cooling hose, fuel injection style hose clamps.
Notes: I installed the B&M transmission filter first, to run the fluid through it and catch anything that falls out from the work I did. At the next oil change, the WIX 51515 will be filled with a fresh quart of Dexron VI and installed for a year. Also, I ended up double clamping everything and used 12 hose clamps.
I wanted to plumb the filter in before the radiator cooler, as hot oil filters better. However, I didn't want to cut the newly installed transmission lines. So, I compromised and cut the existing line from the radiator to the external cooler. Good enough. I cut the hose in the transmission line in the middle. I used the straight bent metal fuel line and transmission cooling hose to connect the upper radiator out transmission line to the inlet of the filter mount. I used the round bent metal fuel line and transmission cooling hose to connect the outlet of the filter mount to the inlet transmission line to the external cooler. It took me awhile and several tries to get the metal lines bent to where they fit snugly and were to my liking.
Looking down at the existing transmission line from the upper radiator port.
I drilled and tapped three 5/16-24 NF holes in the frame to install the filter mount. I made a template from the mount holes, and used my transfer punch set, and still drilled the holes a little off. :mad:
Remote transmission filter mount and B&M filter installed.
Looking down at the remote filter installation. Note that I secured the transmission line with a P-clip and spacers to the passenger's side fan shroud. There was already a hole there. Just put a bolt, spacer, and nut on it.
Another view of the remote filter installation.
This remote filter still fits under the front air deflector. Yet, if it leaks, the leaks will fall out the back of the deflector and be seen by me.
skpyle
skpyle
Senior Member
Now that the remote filter had been installed, I could flush the fluid. This was definitely one of my main goals. I am a firm believer in fresh, clean ATF in an automatic transmission. The fluid in all my automatics gets changed every 2 years, whether it likes it or not. The remote spin on filter gets changed every year. I was spoiled by my Explorer, it had a drain plug in the torque converter and I added a drain plug to the transmission pan. I could get over 12 of the 13 quarts of ATF that it took out with each drain. This remote filter will let me do that for my Escalade.
Before I even started the engine, I removed the B&M filter. I positioned an oil drain pan, 1 gallon jug, and large funnel directly under the filter mount. Cheating and using the remote start, I started the engine. And watched a steady stream of Dexron VI flow out of the filter mount. When the jug had approximately 3.5 quarts in it, I shut off the engine. While the filter mount stopped drooling, I added 3.5 qts of fresh synthetic Dexron VI to the transmission. Then, empty the jug under the filter mount. This is IMPORTANT! I missed this step one time... Lather, rinse, and repeat. I ran 4 gallons of ACDelco Dexron-VI full synthetic ATF 88865618 through the transmission until the fluid out of the filter mount ran clear and clean. Reinstalled the B&M filter and called it good.
Once all was said and done, and the transmission was up to temperature, I did have to add another 0.5 qt of Dexron-Vi to bring the level up to the middle of the HOT mark on the dipstick.
Good for another two years.
Flushing ATF into the funnel and jug.
Early flushing fluid. Not bad, but not good.
Hodmjstone
