Keeping coolant and transmission temps under control when towing in the summer heat
alpha_omega
Michigan
Made it through! One thing that comes to mind is that I have no way to know that my 2012 doesn’t already have 700w fan motors even though it doesn’t list the K5L cooling package. It does have 5 bladed fans and it has the heavy duty towing package, as evidenced by the factory trailer brake controller, engine and transmission oil coolers and the power steering fluid cooler.
My 11’ does not have the factory brake controller which is sad. Granted the one I have may be better, but it doesn’t talk to the vehicle like the on-board one does. This is especially useful with the new magnetic-ride.
Did you buy your 12’ new or used? Just wondering if the PO could have changed the motors.
alpha_omega
Michigan
A fair concern, for sure. However, the area above and below the bumper are isolated from each other by the thick plastic splash shield that runs from just below the radiator to the frame crossmember beneath the harmonic balancer.
Did you end up tucking your cooler inside the splash shield area or is it sitting below the shield? For some reason I thought you guys removed the shield entirely.
So I misspoke earlier, my 2012 is actually five blade fans, and that’s what I ordered as well to go with the 700 W fan motor. There are no markings for part numbers on either the fan or the motor.
there are markings on the motor, the numbers are stamped in the metal on the deep side of the motor case near one of the 3 bolt tabs, you will have to hold it under some light and at angle to see it, and could I see a picture of the backside of the fan blade? the front looks like the same patent number but that doesn't really many anything as there can be variations
the numbers on the motor will be around one of these area's, it will say bosch nearest the bolt fin area and have a list of numbers under it
also the harness connector for the right motor has either a blotch of white paint on it or a nice painted white strip, my theory is the blotch of white painted one is 700w? just a theory based on photos I have looked at, could simply be they changed the way they marked them over time.
RooTBeeRthe1st
I have to laugh whenever I see the words “HD Aux Trans Cooler” in regards to a vehicle with the payload ours have/had.
Is yours a PPV? I don’t own one so I’m not sure what they have other than the Z71 and/or Z95. Mine is the Z55. Is their fan setup any different?
Yeah, that's not much of an auxiliary cooler that they put on there.
SSV 4wd
I mean, I have the k5l option. So I guess 700 watt 5 blade rimless fans. I don't know if one or both are 700 watt though.
I did have to trim the shroud a fair amount to get it to fit fairly flush with the Cold Case.
Apparently I *had*
ZW7 - PREMIUM RIDE SUSPENSION
RooTBeeRthe1st
Uuhhh, they typically have a splash shield there?
Must have been one of the things they removed on mine.
SSV 4wd
Apparently I *had*
the oem oil cooler, power steering cooler, radiator, are the same on all k5l optioned 1500's and ssv/ppv & some hummer's there is no difference at all
probably the same on the 2500's as well it's only when you get up into the diesels & 3500's+ that it changes to bigger beefier stuff.
St. Louis
I don't have the K5L rpo on my 2012, but I have the aux trans cooler, oil cooler, and power steering cooler. My fans are rimless 5 blade and have Bosch motors. I don't think they're 700w, but when on high they are loud and blow/suck a bunch of air. I mean you can't stand in front of it and have a conversation without yelling.
1BADI5
DMV
I think either my HVAC control panel or the clutch on my AC compressor is going **** up. I ran a series of test/diagnostics early. There is an in consistency with the system.
Sometimes it will freeze you out and other times it's Luke warm at best. System and refrigerant were serviced the beginning of spring. Got to much **** going on.......gonna have my buddy who's owes a shop run a full diagnostic on it this week
Geotrash
Geotrash
Dave
Richmond, VA
I bought it used, but the trailer hitch had never been used, so I would be very surprised if there was any reason for them to upgrade the fan motors.
Geotrash
Geotrash
Dave
Richmond, VA
Same. And when I’m towing up a hill, and those fans kick in, the coolant temperature comes right down
alpha_omega
Michigan
Which makes sense when you take into consideration my post regarding less blades = more noise.
alpha_omega
Michigan
Make sure your fins are clean, your cabin air filter is clean and the fins are clean, your PAG oil could be low, there could be an issue with a ground or wire in the harness, a relay could need cleaned/secured better, or one of the temp sensors could be going bad or have a faulty wire. All of these can cause the issue you described.
-How does the a/c clutch feel when you spin it. Free, any grinding?
-When was the stretch belt last replaced?
Geotrash
Geotrash
Dave
Richmond, VA
Sure, here you go. Those numbers on the side of the motor are super faint. So even with my best reading glasses, I can’t be certain that I got it right. Looks like 3137230016.
1BADI5
DMV
I think I have narrowed is down to either the clutch or the actual HVAC controls. I'm leaning in the control side. This morning when I turned off the AC button, it started blowing cold instead of warm ambient air. BUT at the same time the clutch is very clunky when it engages.
I converted from that dumb stretch belt to the early belt and tensioner set up
St. Louis
Drewphil
