2012 Yukon Denali 6.2L — Coolant Temps Rising Uphill in Hot Weather
beeswax
Hi everyone,
I have a 2012 Yukon Denali 6.2L with 105k miles. I bought it about 3 years ago at ~94k miles.
This summer, when outside temps are above 90°F, my coolant temp will slowly climb past the midpoint (210°F on the gauge) whenever I’m going uphill for 5–10 minutes. If I reduce speed/load and shut off the A/C, the temp drops back to normal—sometimes within a minute, sometimes it takes closer to 10. It did happen once without the A/C on, so I don’t think it’s an A/C-related issue.
In the two previous summers (also very hot here), I never had this problem. I could run the A/C all the time and the coolant temp always stayed at the midpoint.
During city driving, slow and short durations, even with steep hills, the gauge never rises past the middle. One thing I did notice: if I shut the engine off for a couple minutes, then restart, the gauge briefly goes above the midpoint but quickly drops back down. Even when it was 110°F city driving, the temp doesn't rise above the middle as long as im driving inside the city.
Work done on the truck:
  • Radiator cracked on the side 2 years ago → replaced radiator (towed immediately, didn’t drive it without one). No issues after until this summer.
  • Transmission rebuilt 1.5 years ago.
  • Installed a custom external trans cooler and deleted the radiator’s internal trans cooler.
  • Replaced a coolant T-pipe that started to develop a minor leak.
  • Full coolant replacement when I bought it, again when radiator was replaced, and partial refill after T-pipe replacement. Coolant color looks normal, no signs of contamination.
  • Oil changes every 3–4k miles, filter every time, oil always looks good.
  • No CEL or OBD codes related to cooling/engine.
  • Tested radiator fans with a scan tool → all three speeds work correctly.
  • Previous owner history: only basic dealer maintenance, except transmission slip.
Question:
What should I be looking at or replacing next to fix this overheating issue?
Thanks in advance for any advice.
Marky Dissod
0. So long as the coolant and/or ATF have not exceeded 230F, they're not overheated, they're just getting close.
I always advise replacing ATF & coolant whenever either has exceeded 230F because I'm a pessimist.
(ATF & coolant temp are measured where it was convenient for GM to put those sensors,
but there are spots where ATF / coolant can get even hotter under load, which explains my pessimism.)
1. Although you did not quantify road speeds, you differentiated 'inside the city', vs ... 'not', I guess?
Over about 48MpH, air's ability to remove heat by passing through a cooler exceeds a fan's ability,
so electrical fans are programmed to shut off to protect their motors.
2. It's sort of an AC-related issue, since AC cools the cabin by heating up the underhood area, however you're right,
it's not the crux of the issue.
3. Ever try using 'Tow/Haul mode' to see if the RpM change from the downshift would improve cooling?
It's POSSIBLE if the engine was at a higher RpM, the cooling system might remove more heat?
(A hidden reason why I recommend ecm & tcm tuning for EVERYONE: better powertrain protection.)
4. You replaced a T-pipe after a leaking. There's always a chance that you introduced air during the replacement,
or did not remove air introduced during the leak? Burp it again with the vehicle pointing slightly uphill, maybe it helps.
5. It's also possible that your ATF cooler upgrade's placement / location might be suboptimal for cooling the coolant.
Moving it to a different spot might help keep the coolant ... cooler.
rdezs
I'd start with cleaning out the radiator fins..... Don't use a pressure washer, just the standard hose end sprayer on a garden hose. Any collection of dust, dirt, pine needles, etc greatly reduces cooling ability. Usually on these vehicles it's not the radiator itself, rather the AC condenser in front of the radiator that has narrower fins. Compressed air works excellent also. I would do this first before proceeding on other options. You may have to use a flashlight and a mirror to get a good look that there or no obstructions.
Next on the list is your thermostat itself. I like to replace them roughly every two years.
You also have to assess if your electric fans are operating correctly. On a 90 to 100° day, with the front and rear AC running, both fans should be blowing full speed. While it could be an issue with a worn out electric fan motor, typically it's just a worn out relay.
Middle of the guage is the normal reading. When you shut the engine off it actually heats up a little bit before it cools, so it's normal if you restart it after a minute or two it will read a little bit higher and should come right back to the middle.
I run all aluminum radiators in both our Escalade and the Hummer H2, which is really overkill in the Pacific Northwest.... But if you live in a hotter climate such as Arizona, it's well worth the money for the more efficient cooling.
Great advice above! After ensuring that the radiator fins are clean, I'd check for any residual air in the cooling system. You could have a situation where an air pocket is forming near or around the temperature sensor, rendering a reading that is higher than the actual coolant temperature.
intheburbs
SE MI
mikez71
Since it's highway speeds, maybe something with the airflow.
X2 on the trans cooler placement.. When did you install the cooler?
If it's large and covering your radiator? Thought I heard that being an issue for someone..
Radiator side flaps still present?
B
beeswax
1. I live in Lebanon, in a fairly small city with multiple steep hills. Inside the city I usually drive around 20 mph, and on some wider roads I can reach 40–45 mph. The steep hills are short but frequent. This is actually the first time I learned about the fans—I only started paying attention to them when this issue came up. I always tried to hear them, but couldn’t. I thought maybe they shut off after a while, or that I just couldn’t hear them over the engine and tire noise when going uphill. Thanks for pointing that out!
3. I also tried driving in manual mode while keeping the RPMs at a minimum of 2k, but it didn’t make a difference. I’m not sure if that’s the same as using tow/haul mode.
4. I parked on an uphill slope, waited until the next day, then opened the coolant tank. I turned on the engine with the HVAC set to maximum heat and low fan speed, then let it warm up to operating temperature and kept it running for another 15 minutes. I didn’t see any air bubbles coming out, and before the second cold start the coolant level hadn’t dropped. I’m not sure if that’s the right way to bleed the system. I’m still trying to find a shop with a vacuum machine to properly remove any trapped air—hopefully that’s the issue.
5. I installed the cooler at the beginning of summer, so I wasn’t sure if it was related to the rising coolant temps. At first I mounted it in front of the condenser, near the OEM external trans cooler. When I noticed higher coolant temps, I moved it to the bottom of the bumper, behind the small chrome piece. Normally that area is blocked at the back, but I opened the black plastic section a bit and mounted it horizontally with an air box. I had a modding shop do the work, and they told me this setup wouldn’t affect radiator airflow since the top and bottom parts of the bumper are separated by plastic and foam.
Deal, first I’ll try cleaning the radiator fins and properly burping the system. I do hear the fans, about a minute after turning on the AC. I even tested them through the OBD connector at all three speeds, and both were working. What I couldn’t verify is that they would keep running properly during a long drive, like 2 hours or so, or if they might shut off if there’s an issue.
I’m in Lebanon, and it does get pretty hot in summer. Isn’t the OEM radiator aluminum? If I decide to go with a custom radiator, would I also need to add an external engine oil cooler?
Might as well be thorough and buy the CO2 test kit, to ensure your head gaskets are good. I just went through this on one of my Jeeps, and it tested positive.
:eek:
If that's the case, shouldn't my coolant level / oil level drop? that's what's worrying me :p
Yeah, the radiator side flaps are still in place with no cracks or wear. When I remove the bumper, I’ll take some pictures to show how the bottom trans cooler placement turned out.
Appreciate all your replies. I’ll report back once I find out. Thanks everyone for the help!
rdezs
The OEM radiators are a rather thin aluminum core, with plastic side tanks. The first place the plastic starts to fracture is directly across where the upper radiator hose enters. When you pull out the original, you'll note the core is only about 1 inch thick. If you get a 100% aluminum radiator, complete with aluminum end tanks, especially with three or four cores.... It will outperform the OEM radiator by quite a bit. One of the first things you'll notice is as the coolant goes from the driver side of the radiator to the passenger side, inside that passenger side tank is your first transmission cooler. The coolant arriving there in the three or four core aluminum radiator is quite a bit cooler than the OEM radiator, and you'll notice right away your transmission runs cooler.
It is one of the few things where the aftermarket is quite a bit better than OEM. And it pays to read reviews before picking one. I've had real good luck with the Champion brand. There's probably several better ones out there for a lot more money..... But looking at the welds on the Champion, I'm more than satisfied.
As I mentioned in our Escalade, it's Overkill in the Pacific Northwest considering we don't pull a trailer with it. But the Hummer H2 uses the exact same radiator, it weighs in over 8,000 lb by itself, and I routinely pull 5,000 lb trailer. My transmission temperature is immediately went from around 200° to 165° with the aluminum radiator pulling the trailer on a 95° day. In town stop and go with the trailer, it might hit 180°.
kikeap
