Sam Harris
Yes,that is how the garage stereo started. I was running 2 12v batts n 2 chargers as the JBL amp sucks up a fair bit of juice.
Have dropped to 1 atm and am going to 13.4v ac[emoji298]DC the hu and leave the amp on the battery.
Lol did you get many complaints from upstairs?
The old man used to bang his shoe on the floor at night n cuss me out with the noise.
[emoji69][emoji2959][emoji110][emoji444][emoji869]
Sent from my SM-G950F using Tapatalk
Oh yes..! I reserved the loud listening for when the house was otherwise empty. And then the neighbors got an earful! [emoji1787]
Man... in those days, I just didn’t gaf at all... Slayer and Deicide, and all kinds of really heavy metal as loud as I could go without distortion. I was such an *******! [emoji15][emoji23]
Lol, weren't we all at that age?
97YukonNZ
Funny you should say.
I had some Quiet Riot cranking the othe day!! Metal [emoji869] Health
Squirrelsmith
Lol so now of course I no longer need chose between 10 or 15 inch sub.
I can run both at once [emoji16][emoji106]
And once I hook this little 1800 watt 4 channel amp up I might add these
Frankenstein looking mothers up!
And the tower of power will be complete!!
Ahhh HaaHaaa [emoji869][emoji444][emoji346][emoji345][emoji344] [emoji83]
wow it's only april and we already have a winner for most bizarre stereo of the year :elephant:
Squirrelsmith
You seem to know what your doing but st
Lo true that!!
It definitely ain't pretty,but it sounds Awesome!! And you cant see none of it when you're driving! Hahahaha [emoji869][emoji1787]
You seem to know what your doing but ignoring all conventional wisdom at the same time. Intriguing combination
97YukonNZ
Hell yeah! Looks great man!
Thanks [emoji106]
Been driving around today and what a change already. Amazing the difference by dropping the centre of gravity and taking a bit of weight off the steering.
Probably going to go down the same road that I read on a thread today that you want to a bit further down the track with a mild cam,performance manifold and a nice pipe on it.
Am enjoying making it a better ride mate ayy!! 1 small job at a time [emoji106]
P.s Like those Valve caps,want me some o those GMC ones! Very cool [emoji41][emoji111]
Guitarded
Edmonton, AB
Discovered there ARE parts for these trucks that are hard to find!
My AC recently stopped cooling. Put it in the shop, would not hold pressure, found a pinhole in one of the AC lines. Had my parts guys do a search, and they could not find an AC line anywhere in Canada. So now it's a week later and I'm waiting for the line we ordered up from the US.
Luckily, I have my daily driver, because it's been around 30 degrees Celsius for the past week or so, and no AC would be horrible.
Shadowz Edge
Drove my old girl around for a small bit after her winter slumber. And I'm still looking for a new air distribution box since mine is busted and I don't have AC or Heat up front
Shadowz Edge
Went to go start my ol' girl this morning. Lots of clicking. Threw a charger on her and topped off her battery. Still lots of clicking. Scratching my head I tested a theory. I took 1 side of a set of jumper cable and jumped from the negative battery terminal to the bolt grounding out the alternator. She fired right up! To finish testing the theory I disconnected the jumper cable, shut her off, and tried starting her again,. Just lots of clicking. Connected the jumper again and she fired right up.
Time for a new cable
Guess since I have a second battery tray already installed on the driver's side I'll look into an all new cable set and do a dual battery setup.
YukonGTmaster
2 Door w/ Barn Doors Club
My rear passenger ash trays have been “broken” forever. Passengers would get in, and immediately start cycling the ash tray lid up and down until both hinges called it quits. I had the ashtrays out and noted that the hinges were only missing a pin on each side. I thought a conventional roll pin might bind up the smooth rotation of the hinge. I had an old U joint in my tool box, so I took 2 of the needle bearings out, and put them in the hinge. Repaired!
97YukonNZ
Haha! If I don’t trust the backseaters to play with an ashtray, I definitely don’t want a .380 for them to mess with. Lol
Or any children,ended up getting car jacked by the family..Yes we are going to Mc Donald's.....Click!
Hahahaha :Get him!:
scottd
