Change oil light won't turn off after pressing gas pedal 3 times
I can not reset the oil change lite, I press the gas pedal 3 times fast after turning the key to run position, I even tried 5 times and stomping the pedal 3 to 5 times, it still won't reset. I literally had the oil changed twice in 1 week, the second time was a mistake service by pep boys wen I ask for a fuel filter Change. I ck oil and the oil lever is fine.
wjburken
Eastern Iowa
Don’t think you reset it by hitting the pedal.
Scottydoggs
NJ
both ways works for my truck. just did the pedal reset a couple weeks ago on my 05. it has a dic, ive re set it from there in the past as well.
if you have no dic you just turn key to run and push the gas pedal 3 times.
Scottydoggs
NJ
It's actually back on again but oh well it compete with the broken fuel light flashing lol
it has been a year, the reset message will come back over and over as the truck deems your closer to a oil change. needs to be reset with every oil change to keep on top of it.
i should see what % im at, i put like no miles on my truck over the year and do my oil changes once a year in march or april, so its been a year since i last reset mine.
MassHoe04
Western MA
Just did pedal reset on my 04 just the other week. Didn't have to press the pedal too quickly. Just 3 times to the floor within 3-5 second time span. I probably could have done it with my Tech 2, but I just got it and it was quicker to do the pedal reset procedure.
Drewphil
