Replace 5.3 l59 with this....
RobsFreeland
RobsFreeland
Old wild land firefighter
Whidbey island
Well now I have to drop support for transfer case. I got the y pipe out. Figure I could get in back in. NOT. Forgot I sawed off the ends which gave me clearance to get it out. No biggie do that tomorrow. Spent most of today just getting the driver side header done. Didn’t have room. Had to remove tire and inner fender well. Boom it’s right there. Still had to futz to get em all in. Had to feed header from below couldn’t drop down from above. It’s in. I had to lay across engine to get at bolts. Got my cardio in today.
RobsFreeland
RobsFreeland
Whidbey island
I agree with this.
I agree with this, as well.
This is why these engines need a catch can!
No. They need to be separate since they're separate directions of flow. But, I'd be more concerned as to why you have so much oil on that side of the intake and in that fresh air intake tube. Do you constantly drive it hard? As @wsteele mentioned, check you PCV system. Yours, being a 2011, should have the updated valve cover. But, running crappy oil or not changing it frequently enough (running dirty oil) could clog up small passages such as that small orifice in the valve cover that acts as the PCV "valve". I'd pull that driver's side cover off to (1) have a decent idea of the condition of the inside of your engine and (2) to clean the cover and PCV orifice thoroughly. I'd try to blow through it to see how difficult it is before and after cleaning to gauge if there was any improvement. Clean the TB and that fresh air inlet hose, too.
Although it’s a different year I wonder if this applies to a 2004 5.3 flex also? I have no Psv valve and I hooked up both lines to one catch can. Passenger and driver hooked together.
RobsFreeland
RobsFreeland
Whidbey island
See the link in the original post for pics on Speed Engineering website. The hose plumbing is very simple. Both valve cover vents go to one side of the catch can. I used the IN side closest to the engine. The passenger side vent tube is above the valve cover and pointing toward the front and the driver side is at the rear of the valve cover pointing up.
The OUT side of the catch can goes to two connections on the intake manifold. The passenger side connection is just behind the throttle body and the driver side is top center of the intake.
The passenger side connections are very short. I routed the driver side hoses in the space under the throttle body and above the water pump.
All the above is for a 2005 LQ9 using a 2004 5.3 flex fuel intake manifold. Others may slightly differ.
The catch can does not have IN and OUT marked, so you can do whatever you like. I got the hose & 3/8" fittings at O'Reilly's.
The clear sight tube is included with the kit. There are no instructions included.
Looks like I can splice both sides together. The can I bought has a filter like a water separator in an air line for the intake side, which I reversed . The line would back up. I want free flow in can then on the exit side the mesh filter.
RobsFreeland
RobsFreeland
Whidbey island
Did it have pcv? Or the egr?
I don't have either one. I didn't realize the valve cover can get clogged. My covers looked good didn't even think about blockage or oil consumption.
Dropped support for transfer case and got the y pipe back into place. Headers almost bolted up lost lock washer had to go get a couple. Support back up. I'm so ffffin close. Pictures of catch can and headers.
RobsFreeland
RobsFreeland
Whidbey island
Well finished header install , a lesson in manual dexterity. Hooked up magnaflow cat back.
Fired that puppy up and low oil pressure.
Day off Superbowl. Will prime oil pump through block. If that doesn't work then on to the new pressure sensor.
RobsFreeland
RobsFreeland
Whidbey island
I did install a new oil pressure sensor, but couldn’t get the screen out. So I left it in captain obvious. Pulled the front off again, water pump, alternator, bracket for power steering pump. Couldn’t get access without doing this. Finally got the plug out of the side of the block (8mm) and put in about 1/2 quart of oil. Got most of the parts back on. Tomorrow water pump, alternator, redo catch can and will wait till it fires with oil pressure before I put in shrouds etc. . It did sound bad ass when I fired it. Just couldn’t let it run for long. I figure if it doesn’t give me pressure like a delay with a normal oil change, then something up and will go after sending unit.
RobsFreeland
RobsFreeland
Whidbey island
Put everything back together...
Started it up and oil gauge moved this time but no pressure. Looks like on to the sensor. Damn. Took recording of tailpipe sound but file is to large. Mp4. Well back at it tomorrow.
RobsFreeland
RobsFreeland
Whidbey island
Pulled oil sensor, bloody mess for my hand. Had to drop fuel lines to get room. Went to parts store and got pick set, fished around down inside to the full length of the pick was worried I would drop it in. What a mess that would be.
Put old one in, nothing, pulled old back out, blood still dripping from hand.
Reading about screens , turns out it wasn’t till 2007 when they started putting screens in. I couldn’t find the screen because I don’t ffffin have one.
Going to leave the sob out and let my hand heal a little bit. Will probably put more oil in and crank the mother to see if something squirts out. Have read it could turn to a mess real quick. Will see.
Going to have local mechanic come over and help. Frustrated man.
Mudsport96
40.923,-89.488. Illinois
Dont want to be that guy, but you put oil back in it right?
I have seen a guy do that at work. He rebuilt a forklift engine, put it in and fired it up without putting oil in the darn thing. It wasnt that he didn't know hat he was doing, was just in a hurry.
RobsFreeland
RobsFreeland
Whidbey island
No that’s what I finally came up with. Putting the dipstick tube back in I snapped the mother the tacked holder was broke. Got another one promptly snapped that one too. Have another on order to arrive next week. 15 dollar part 45 for shipping. When I put the thing back together I was pouring oil over rocker arms, gears etc. , maybe not enough got to pan , will check today. Definitely used six quarts when I did it. Was wondering how much oil an can an engine hold in suspension?
Mudsport96
No, if you put six in it there should be 5.5 in the pan and half a quart in the filter. So quick test if the pump is working, take the filter off and see if it has oil in it.
Or did you prefill the filter?
RobsFreeland
RobsFreeland
Whidbey island
Snowed here about 6 inches . hung around for three days, then rain melted everything. Weird.
Had local scan guy come over look at oil pressure sensor to see if it was working. Figured oil pickup tube was faulty. Dropped front axle and pan, it was faster this time, and you can see the o ring not sealed. Ordered part from azon should be here sat. Still waiting for order from the 6th.
https://www.amazon.com/dp/B01L9VR3M6/ref=cm_sw_r_cp_apa_fabc_SYHWCEY4BEQYPA03J2DG
Hope this helps somebody else to avoid this problem. Cheers
RobsFreeland
RobsFreeland
Whidbey island
I might add the pickup tube only had one bolt. The flange was designed that way. The part should synch up the tube and be held by two bolts.
chadw
Stay ahead of trouble? Yours has 220k on it. Its no spring chicken, but theres no upcoming trouble. Why would you waste money and time on this? If you really wanna stay ahead, go ahead and replace the ************* transmission and rear end these turds came with.
Bentley95
