Mild 6.0L Build Suggestions?
Mudsport96
40.923,-89.488. Illinois
I knew they had aluminum and iron diffs, but didn't know they had the same part number. Interesting! I guess that's why everyone on s10forum always said "you just have to look at it" when people were searching the yards and online for them.
Yeah pretty much why that was said. But, over on the old zr2usa forum, we kinda narrowed it down to the following.
Regular 4x4 auto aluminium
Regular 4x4 manual random
ZR2(Highrider) and BlaZeR2s auto aluminium
ZR2(Highrider), BlaZeR2s manual Iron
AWD Astro aluminum unless it had the tow package then it was random if it got iron or not.
Mudsport96
That is wild... I wonder if the cast iron front diff could take a locker?
Sent from my SM-A505U using Tapatalk
Lot of guys on zr2usa ran lockers in the aluminum case with little case failures was mostly the stub shaft.
I never broke either, i broke 10 rearends, 2 tcases, 3 60es, and a 4.3. No front diff or cv issues. Lol
Hijack over
"Random"- Just like with the "hop shock or not" S-trucks. Or was it the hop shock bracket that was random? Whatever...
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
Wow, I knew the stub shafts break. The new ZR2 comes with a locking IFS. I'd be inclined to install a locker in my front diff, I wonder how easily they break haha
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
I interviewed a machine shop. Guy really knows his stuff. Going to dropoff rotating assembly as soon as I gwt the other rods in, stupid ebay seller is slow as mollases with shipping.
He recommended using the 5.3L heads, then he would cut larger intake valaves in them for me. He said the torque would be mich better...
I was always relicrant about the 5.3L heads due to compression being higher... I would be unable to run low octain (I go places where there is as low as 84 octain and nothing else sold. Makes me want to bw super careful about the compression ratio.
However he said he cc'd LQ9 setup and got 9.2:1... despite factory says they are 10.1:1
He said reguardless get a trailblazer ss intake and 90mm throttle body.
Any thoughts?
Any thoughts?
I agree to all.
The 706 heads are great for mild NA builds and really just need larger valves, as he proposed to do.
Yes, most, if not all LS heads' chamber volumes measure lower than advertised. This is why, when I'm aiming for a particular CR, I tell my head guy to "mill 'em to XXcc, but shave no more than XX thousandths."
The standard Gen4 intake manifold IS a "TBSS" intake. Get a manifold off of something boring like a cargo van. It'll be cheaper than one from a TBSS, yet it's the same thing.
I don't know if there's an adapter to plug in a stock Gen4 87mm TB. If there is, it'd probably be almost the same cost as a 90mm TB (LS2). So, shop around.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
So you think the 706 heads with larger valves would generate better power / down low than the 317?
Any idea what compression ratio the 706 heads would be with the flat top 6.0 pistons?
I am super concerned about compression as I go to places where they sell as low as 84 octaine and you cannot find any higher than 87.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
I will let you know :) thanks, reading up on everything yet.
Prob definately need the bigger 90mm tb. However cannot find a used one for sale. there are a bunch of generic ones for cheap... but not sure if I want unproven chinese parts haha
I def wouldn't go the china route.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
Do you know what LS builds used the 90mm throttle body? Guy at machine shop made it sound like factory 90mm throttle bodies were falling out of trees.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
I am bot sure why guy at machine shop recommended bigger intake and throttle body... other than he builds more racecars than trucks?
I love idea more torque with smaller heads... but I really cannot afford to increase compression.. I go to places where there is no fuel at higher octain for that level of compression. I am already bit worried about the flat top pistons.
I don't understand all the factors though... Depending on when events takeplace with cam, will effect compression (i think). Also I would assume the smaller intake ports flow / scavenge better at low rpm than the bigger ones on 317 heads.
I know it would be a pain, but for special cases you could always carry a few cans of octane booster--to add to low octane gas.
Better low end, but they still won't choke it in the upper end, either. I can't say for the compression ratio because I don't know what your actual chamber volume is. The only way to know is to measure them. They're pretty much always larger than what GM specs. If you're not the original owner, you probably don't know for sure if they've ever been milled, either. Once you know the volume, then you can do the calcs to determine your SCR. If it's too high, run a thicker head gasket to drop it to where you want it. The chamber volume will change with the new valves.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
So the connecting rod mystery continues. I ordered another set of rods w/o the oil relief. They are refuebished and look like new. However, there is no casting number anywhere on any of the rods... It is super weird.
Dantheman1540
Sugar Loaf Mountain
The 90mm TB came from ls2s and ls3s. The gold blade 90mm is from the ls3s and is great for NA engines or low boost they tend to snap shut under high boost. The silver blade 90tb is from the LS2s and is the holy grail of OEM TBs, I think they go for $200-$300 last I checked. Anyway, they love boost and most big boost guys are running them. I've had one on my Silverado at 18psi and it never had any issues.
Mudsport96
The trick is not larger valves, but unshrouding the existing ones in a 706 head. Get some 6.0 head gaskets and lay them on the 706s, then use a marker to trace the bore of the gasket. After that you slowly make a relief in the wall of the chamber next to the intake valve and that will help increase flow. Putting a larger valve in a 706 head will move it closer to the chamber wall and increase shrouding and not increase flow as much as you would think. You can unshroud yourself vs paying someone to cut the head and buy valves.
I'll look around and see if i can find the info, then post it back here.
Mudsport96
-6.7 CC Dish Pistons...
They flow nearly the same....
Flow data (317 Heads)
Lift In. Ex.
0.050 33.3 24.5
0.100 63.4 54.2
0.200 144.1 103.8
0.300 200.2 142.5
0.400 234.6 167.9
0.500 241.7 183.1
0.600 243.3 193.7
0.650 244.8 195.1
Flow Data (243/799 Heads)
Lift In. Ex.
0.050 31.1 24.7
0.100 65.4 52.6
0.200 142.2 98.1
0.300 193.5 133.5
0.400 230.2 160.1
0.500 243.4 175.5
0.600 248.1 185.8
0.650 249.3 188.2
http://www.superchevy.com/how-to/en...numbers-from-our-stock-ls-cylinder-head-test/
I couldn't find the page i thought i had saved, but here is some information from this site. The 317 is basically the same as the 799/243 heads everyone loves. But Richard Holdener did a comparison of 706 vs 799s on a cammed 6.0 and the results were interesting.
Below 5500 the 706 heads made more hp and tq. Above that the 799s made more power. How often are you going to be over 5500 revs? And these heads hadnt had the valves unshrouded.
jpurdie
