6.2 swap thread
randeez
south florida
what IAT sensor you going to be using?
i grabbed an LS9 hoping its a little more responsive than the old LT1/vortec ones, uses a weird 12mm or 14mm thread tho
L
ls1frc
Flex fuel sensor ordered and OTW.
Likely last two mods I do to this thing. After this, it's just fixing the paint, taking care of the rust as best I can and whatever else comes up.
I had plans to possibly do a blower, but its fast enough for me N/A considering the size of the vehicle. I'll save that money for a 2nd, fun car.
L
ls1frc
I use it to fix the lean hot restart issue with cammed vehicles.
When your truck is fully up to temp, and you park it for 10 minutes, when you go to start it the IAT is cooked and reading way higher than the real air going in. The ECU then compensates, thinking the air is not as dense, and pulls fueling making you go way lean. On a stock cam, no big deal really. On a cammed car, it leads to a shit idle for a few minutes until air starts moving over the IAT and gets the fueling back in line.
So I relocate mine to somewhere in the airbox.
Speck
Olympia, WA
Just read the whole thread, and all I can say is Wow! Very nice job on the build! I'll be following this for when I get ready to do engine work on my L92. :cheers:
L
ls1frc
Already got the good engine then. VVT cam and headers and have fun with your extra 100 hp lol.
L
ls1frc
Cold start "clack" only had about 2 clacks before it quieted right down. I am gonna give it another tank of gas. If still doing it, I'll contact Johnson.
Drove a good 100 miles today. The 6.2 is amazing...
L
ls1frc
Had an hour, decided to try to tackle the starter thinking it would be easy.
With the headers in place + the front diff, it is not easy to get to it. I can get it out of the mount but not sure I can drop it down, so I put it back up for now.
I'll need to just allocate another half day for that just in case I need to remove more shit. I am hesitant to remove the header because I use remflex gaskets and they are one time use.
L
ls1frc
I'm thinking, pull the tire, pull the wheel liners. And that will make it easier to get the starter wire off. From underneath, may just need to drop the swaybar down.
L
ls1frc
Flex fuel kit just got here. I was able to get it for about $200, so about $100 off. Since ChadW was able to determine I am poor because I prefer to keep my vehicles longer and mod them/tailor them to my needs, every penny counts. I am grateful!
Yeah, you should be grateful...
Grateful that you can justify it in your mind to fix your old heap of GM trash. Broke-ass peasant.
scottd
