kbuskill
NE. FL.
It's been off all July/August. Haven't noticed anything above 210 on dash.
Sent from my SM-N950U using Tapatalk
Yeah the gauge in the dash is well documented to be inaccurate.
It is believed that GM programmed it that way on purpose so the needle sits in the center of the gauge and doesn't move alot so that soccer moms, and the like, don't think something is wrong if the temperature fluctuates.
If you look at the actual temperature readings via a scan tool it should run about 192°- 194° on average.
I just thought I would mention the possibility of cooling issues because a lot of people don't realize that the air dam serves a purpose for cooling, not just aesthetics.
These arrived yesterday.
Spohn boxed rear LCAs with poly bushings. The bushings on the OEM LCAs are smoked.....so might as well upgrade. These are also lighter then the OEM stamped steel shit.
Improving and dropping weight where I can
I have those on my 02 Denali, I’m happy with them. Same thing, I was replacing the stockers as maintenance and figured why not.
89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
Trimmed off the clip's and the tabs of the bracket for front fascias lip. I think it look's better without it [emoji2373]. Also put my new headlights in. I need the fogs now.
Read your post and did the same tonight. Thanks. I left the 2 sections where the brackets were as you can see. But much better looking.
What is the VTEC characteristic?
Back in the day, Honda had their first iteration of a variable valve timing system, called "VTEC" (Variable Valve Timing & Lift Electronic Control). It wasn't like today's variable valve timing that has a range of adjustment. It just had two modes- low RPM and high RPM, and there was a distinct difference when it would shift from one mode to the other. Modern variable valve timing systems have a wider range of adjustment to optimize the valve events across a wide band of RPM, so any changes are undetectable.
My reference was to the original VTEC characteristic. I floor the Tahoe from idle and it climbs in RPM as it accelerates. Somewhere around 3,000 RPM, it suddenly comes alive and the RPMs climb much faster to redline, with the accompanying rush in acceleration.
I'm convinced it's Torque Management retarding the timing until around 3,000 RPM.
Thinking since i didn't get the torque right, i might as well pull off the pan again and add that part.
Doing more reading, it sounds like a good idea.
I'm also going to replace the pressure sensor and screen.
I flushed quite a bit of gunk from that bypass, probably a good idea for peace of mind.
If that valve was gunked up, then your AFM system would look the same on the insides. Buildup is the #1 killer of AFM components due to the tiny passages all throughout. Gotta keep clean oil in it! You also can't flush the engine with harsh chemicals since they aggressively break up the crud in larger chunks. These chunks move through the system and get lodged in the oil passages in lifters, push rods, the solenoids in the VLOM, etc. You gotta gradually dissolve the deposits over time with the detergents in quality oil.
Do you track your engine's oil consumption? Have a catch can?
By the way, the torque specs are just as you found: 18 ft. lbs on the pan bolts and 106 in lb. on the two long skinny ones at the rear. DO NOT attempt to tighten those two rear bolts to 18 ft. lbs.
Just Fishing
Can't fix stupid
Utah
I haven't had the hoe very long, but i do plan on adding a catch can.
I have one on the old vette, pcv system would pass oil to the #2 cylinder... pita with the wide band 02 sensor and tuning.
After running with it for a while now, I'm sold on the catch can idea.
:893karatesmiley-thu
And it was something i noticed after the first oil change in the hoe.
I like to use a half can of seafoam in the oil every few oil changes, drive for a short time and then change the oil and filter.
I did that with the hoe and was amazed how bad the oil looked, it upset years of built up gunk.
Stupid oil change monitor...
In my wifes car i use it as a general reminder, but i go off of how the oil looks vs miles.
But then again, I'm pretty sure the hoe was someones heavy duty minivan... lol
Should have seen the brake fluid... :confused:
I also have noidea what kind of oil the po used.
Per the carfax, the oil changes were mostly done by the dealer, and just a few quick oil change places.
This is the Highest mile car i have ever purchased... lol
I always go by the 3-4k mile, or every season. What ever comes first rule.
I have been running this thing with the dod/afm disabled via hp tuners.
Think there would be any benefit to enable it for a short time after i have everything sorted to hopefully flush the system out a little?
Or better to keep it off until I'm ready/willing to do a full gut and a mild cam thrown in?
Also, i haven't noticed any change in the oil level.
But i also haven't driven it much yet.
Maybe a thousand miles or less.
the_tool_man
Upstate South Carolina
I'd leave it deactivated. My reasoning is that the lifters are held rigid by a pin that is retracted when AFM activates. If the pin never moves, the lifter can't collapse uncommanded unless a part physically breaks. If you turn on AFM, the pins may retract but not return to the "locked" position, leading to failure.
Buford bubba
