Ahh now I see it, mine is cracked after I railed a construction cone that must of fallen off a truck. Only 1 cone, I found it at 80!
Been there, done that! This one actually bent my shifter cable. I didn't realize it til I thought it was in park and it starting rolling backwards.
89Suburban
Bull in the china shop
SE PA
Any sign that gets run over and doesn’t snap off at the base turns instantly into a spring loaded giant knife sliding under the chassis. I did have one slice right through a rear shock absorber once.
89Suburban
SE PA
Oh so I found one of my upper ball joints is wasted and it was supposed to go in for inspection Tuesday.:mad::mad::flipthebird:
osiris94ej
Casper Wyoming
Mine got ripped off last winter backing out of my driveway over the curb. Messed up the left fascias bracket and fender got bent a up a bit. Cracked the paint, but I got it bent back as good as i could. Lowered 2/4 and if i caught it on the curb when the front end was stock, im better off without it.
Sent from my SM-N950U using Tapatalk
Just Fishing
Can't fix stupid
Utah
Just thought of another while-you're-in-there item: AFM pressure release valve deflector.
Part #12639759
https://www.amazon.com/General-Motors-GM-Deflector/dp/B00CMTK3QI
Thinking since i didn't get the torque right, i might as well pull off the pan again and add that part.
Doing more reading, it sounds like a good idea.
I'm also going to replace the pressure sensor and screen.
I flushed quite a bit of gunk from that bypass, probably a good idea for peace of mind.
kbuskill
NE. FL.
Trimmed off the clip's and the tabs of the bracket for front fascias lip. I think it look's better without it [emoji2373]. Also put my new headlights in. I need the fogs now.
Looks good but keep an eye on your coolant temperature. The air dam is there to create a low pressure area behind the radiator.
Dallinz
