If that valve was gunked up, then your AFM system would look the same on the insides. Buildup is the #1 killer of AFM components due to the tiny passages all throughout. Gotta keep clean oil in it! You also can't flush the engine with harsh chemicals since they aggressively break up the crud in larger chunks. These chunks move through the system and get lodged in the oil passages in lifters, push rods, the solenoids in the VLOM, etc. You gotta gradually dissolve the deposits over time with the detergents in quality oil.
Do you track your engine's oil consumption? Have a catch can?
By the way, the torque specs are just as you found: 18 ft. lbs on the pan bolts and 106 in lb. on the two long skinny ones at the rear. DO NOT attempt to tighten those two rear bolts to 18 ft. lbs.
I haven't had the hoe very long, but i do plan on adding a catch can.
I have one on the old vette, pcv system would pass oil to the #2 cylinder... pita with the wide band 02 sensor and tuning.
After running with it for a while now, I'm sold on the catch can idea.
And it was something i noticed after the first oil change in the hoe.
I like to use a half can of seafoam in the oil every few oil changes, drive for a short time and then change the oil and filter.
I did that with the hoe and was amazed how bad the oil looked, it upset years of built up gunk.
Stupid oil change monitor...
In my wifes car i use it as a general reminder, but i go off of how the oil looks vs miles.
But then again, I'm pretty sure the hoe was someones heavy duty minivan... lol
Should have seen the brake fluid...
I also have noidea what kind of oil the po used.
Per the carfax, the oil changes were mostly done by the dealer, and just a few quick oil change places.
This is the Highest mile car i have ever purchased... lol
I always go by the 3-4k mile, or every season. What ever comes first rule.
I have been running this thing with the dod/afm disabled via hp tuners.
Think there would be any benefit to enable it for a short time after i have everything sorted to hopefully flush the system out a little?
Or better to keep it off until I'm ready/willing to do a full gut and a mild cam thrown in?
Also, i haven't noticed any change in the oil level.
But i also haven't driven it much yet.
Maybe a thousand miles or less.
