FRONT DRIVE SHAFT
GM#23104840 JOINT KIT, F/AXL PROP SHF UNIVERSAL (W/INTERNAL SNAP RINGS)
REAR DRIVE SHAFT
GM# 89059111 JOINT KIT, PROP SHF RR UNIVERSAL (OUTSIDE SNAP RINGS - DANA SPICER) (3.625" X 1.187") (W/ EXTERNAL SNAP RING TAB ON GROOVE ON DIFF P/GR YOKE)
Interesting the rear is listed as a Dana Spicer but the front says universal. Wonder if it’s Dana Spicer too. That’s the brand I used for all 4 on my 02. It’s always been my go-to for u-joints.
1BADI5
DMV
What about the 4x4 spindles?
I can not say for sure......as in I only test fit on a 2wd. Now if the current calipers are the same by part number for the 2wd and 4wd.....one could assume that it "should" work with 4wd.
I only speak to the absolute facts that I have via actual hands on parts/installed
PG01
Up here to the right
FRONT DRIVE SHAFT
REAR DRIVE SHAFT
I’ll thank you Rene.... @Doubeleive forgot......lmao
FRONT DRIVE SHAFT
REAR DRIVE SHAFT
thanks!
are the ones you bought greasable?
No. I don’t believe in greasable u-joints. The originals lasted 150k without adding grease. And in reality, when I replaced them there was still plenty of grease and they didn’t even look worn.
the rear ones are $90 each the front ones are $45 each :eek: for oem
Interesting and I think my question about the manufacturer of both was answered. Since the rears are listed as Dana Spicer @$90 each and the front are listed as universal @$45 each I’m pretty sure the fronts aren’t Dana Spicer. I bought mine ( Dana Spicer for my NBS) from RA for $22 each.
the picture doesn't show the rear ones close enough to determine a manufacture stamp, but the dana is less than half the price, the front shows a stamp DD 14 ?
Leno1364
