George B
¯\_(ツ)_/¯
Me too, I wonder if they can do something different than a sport mode.I was afraid of that. I would need tow/haul mode occasionally.
I mean, The Beast doesn’t have a sport mode but engaging tow/haul does change the way it shifts enough that it might as well be sport, it revs higher before shifting and downshifts sooner so with my blower it’s pretty damn sporty!Me too, I wonder if they can do something different than a sport mode.
I already use tow haul mode alot just for the improved drivability.I mean, The Beast doesn’t have a sport mode but engaging tow/haul does change the way it shifts enough that it might as well be sport, it revs higher before shifting and downshifts sooner so with my blower it’s pretty damn sporty!
Damn. What a PITA. I still need to upgrade my heads to a retrofit, but I lack the skills or time to do it. My Fleece works for now anyway. I can still use the fogs independently, but do have the “all-on” with the high beam switch. [emoji106]I was reading the “ what did you do to your NBS today” thread and the discussion of the Fleece all-on module came up and it was mentioned there’s a version for the NNBS so I looked into it, and then remembered why I didn’t really like their modules. I have Morimoto XB LED fogs with the Morimoto bi-xenon projector retrofits (which open the HID shutter and turn the other bright bulb on when the high beam switch is turned on) and am running LED high beams and I want the fogs to come on when the headlights come on which the Fleece modules don’t do, the fogs only come on with high beams. So...in the tech section is a thread on adding a jumper between the low beam and fog light relay. So I added it and turned the lights on to see if it worked. The driver side had low AND high beams on, along with the fog. Passenger side worked fine. And when I hit high beam, the ds didn’t change at all. Shit. I figured I had caused the problem when I added the jumper- either messed up the BCM or a relay in the fuse box or one of the Moromoto relays. So I pulled things apart and started troubleshooting. During this process my ds high beam LED quit working so I was using a halogen bulb to troubleshoot. I tried swapping relays in the fuse box, in the harness, disconnecting the battery hoping to reset the BCM, hooked up the Tech2 and went through all the menus looking for something. Nothing. Then I looked at the vehicle harness that goes between the truck and headlight/ HID ballast. There’s a split jumper that connects both the high beam shutter and the high beam bulb. It’s supposed to connect to the high beam connector on the harness, and the other headlight connector on the harness connects to the ballast for low beam. What if.... shit. I had the splitter connected to the low beam side so when the low beams were on, the high beam was on too. And the shutter in the projector wasn’t working. I hung my head and ordered a new set of LED high beams. Stupid wiring. There’s so much of it for my headlights it’s confusing. I got my label maker out and labeled the wires. I’ll get everything back together before trying the mod again.
Thank you.Just got through looking at this thread, took a few days.
That is a great looking truck to start and you have made it even better.
Nice job
. So I was going to buy another used bcm and send it to White Automotive to have the hyper flash disabled which they do for $200. Plus it would cost for a used bcm and shipping both ways. I decided to see if anybody does it cheaper and came across an article from EFI Live that said they partnered with a couple guys to do custom bcm flashing via Autocal. I just ordered a bcm tune from www.btdieselworks.com which they will email to me and I can load it into my Autocal to flash my bcm with. I ordered hyperflash disable and extended remote start run time and unlimited re-starts for the same price as White Automotove, $195 with no shipping. I will update after I receive the tune files. Here’s the article from EFI Live.Changed out? I’m not changing out the bcm, I’m going to plug my Autocal into the OBD port and flash the bcm with new software provided by the tuner. As for what White Automotive used to do, they required your bcm to be removed and shipped to them and they would program it and send it back so your truck would be down while that happened, or you could buy a new or used bcm and send it to them where they program it to your VIN and add the custom tuning. But regardless, the bcm’s for all the 07-14 1500 trucks and SUV’s are the same afaik, possibly the 2500 and 3500 trucks too.So the BCM can be changed out between the model years? Also you can use different programs to tune? I was under the impression that you could only use one or the other...
I have been trying to fix the damn hyper flash on this truck forever. Nothing I’ve tried has worked and I have tried EVERYTHING as far as load resistors. According to the Tech2 it’s the fronts, and since it has both upper and lower turn signals I can’t tell which ones are causing the issues. I have tried one 3 ohm resistor per circuit, one 6 ohm per bulb, one 3 ohm per bulb, etc. Every time it works with either the key on engine off headlights off, engine running headlights on, engine running with headlights off, key on engine off headlights on etc...it’s driving me absolutely. So I was going to buy another used bcm and send it to White Automotive to have the hyper flash disabled which they do for $200. Plus it would cost for a used bcm and shipping both ways. I decided to see if anybody does it cheaper and came across an article from EFI Live that said they partnered with a couple guys to do custom bcm flashing via Autocal. I just ordered a bcm tune from www.btdieselworks.com which they will email to me and I can load it into my Autocal to flash my bcm with. I ordered hyperflash disable and extended remote start run time and unlimited re-starts for the same price as White Automotove, $195 with no shipping. I will update after I receive the tune files. Here’s the article from EFI Live.
https://www.efilive.com/latest/news/bcm-flashing/
Yeah I saw that after my other post and I went to their website. You can even disable TPMS with it.White's doesn't actually reflash the BCMs anymore from my understanding. They partnered up with BTdieselworks. They also have a module called the "Autosync" that has some pretty cool features including rolling up or down your windows from the factory remote.
2007-2014 AutoSync (GMT-900) – BT DieselWorks
https://www.btdieselworks.com/collections/electronics/products/autosync
But...the AutoSync can’t disable hyperflash or extend remote start run time or change DRL settings.
