nice!, did you use led's or go with some lights from the nbs's?
gm has gotten cheap they used to put in door marker lights, footwell lights, glove box lights, ashtray lights, underhood light.
Yeah, there’s just minimum lights now- dome and map lights are about all. I used some led lights that are mounted to metal plates that I had laying around. They came with double sided tape and I just found flat spots to stick them to.
DEAD65AD-DDAD-42A5-91CF-344894F79554.jpeg 19095E64-FE5C-41C7-8368-795177CF10AE.jpeg
R3cord303
Posse In Effect
Oregon Valley
I drove across a back road weigh station, and i had a bunch of random crap in the back, but I wanted to get an idea of weight distribution and in general how heavy the tahoe is. 3100 on front axle, 5800 vehicle weight, and 2800 on rear. I think If I take all the stuff out, and I’m not in it, I’d be at or around 5550. I’m 170 pounds, there’s three duffel bags in the back, and I had just gotten groceries and gas.
DF5B93F8-2E73-4FBB-83EA-104257BBC035.jpeg 3DBDEB38-9725-41F1-ABE1-157916ADB433.jpeg 7E767AF9-FF02-46E8-9C22-6DCA498E88A0.jpeg
View attachment 248581 View attachment 248582 View attachment 248583
The scales math is off by a hundred pounds.
89Suburban
Bull in the china shop
SE PA
So what do you think the reason you were getting all the codes?
I think I was losing oil pressure through the middle unreplaced gaskets. And the solenoid frame is riveted in place. So after pissing 300 bucks away on useless non-returnable gaskets that refused to match, plus trying to trying out how to install a correct one, if I could find it. I did dissect and cut the keepers on the old one, and punched the rivets out of the casing.
I was thinking, even if I found the right gasket, how do I put it back together? 1/4” nuts and bolts? Although I was tempted, NO. No redneck shit!
Did some more relentless internet searching and found this complete cover assembly. Dropped another 200 bucks minus the 20 percent, online discount of $50 at local Autozone.
And here I am and tired and beat to shit. Physically, mentally and financially on what was supposed to be a medicore preventative oil leak fix.
Anyway she is running great!
89Suburban
SE PA
Oh, the flat tire? After I got her running, I had to address that issue. Pulled it off filled it to 50#, soaked he shit out of it with soap water tread, sidewalls, bead, valve stem. NO bubbles or leaks I can find. ??????? I’m so whooped.
89Suburban
SE PA
That’s awesome, and you got it done before work tomorrow? Was that a new valley pan with solenoids and gasket? I’m just glad I’ve never dealt with AFM. I would rip that every part of that shit out, run a good cam, and never look back.
Yeah brand new. If I was in a different situation I would love to do what you propose.
BrentL9900
