89Suburban
Bull in the china shop
Space X Supporting Member
SE PA
M123
Viking
Sweden
Can the foam be something they did use for lowering intake noise and even from lifters? :)
I would not reuse any gasket even if would be okay, too much problem if it's fail and you need take everything down again. :)
tHIS WHOLE PROJECT HAS BEEN A SHIT SHOW FROM THE BEGINNING!!!! Ok found a gasket 15 miles from here......
These things rarely go as planned. Sorry for your issues but I’m sure you’ll overcome. Don’t feel bad- the first time I installed my blower which is a real ***** due to the placement of some of the bolts by the firewall that are nearly impossible to get to, I found out the “extra” intake gasket that I didn’t see a need for nor any way to install it WAS actually needed, they just forgot the extra instructions. It all had to come back apart.
They must've got their instruction cues from DJM! Don't these assholes think we consumers need directions to put their shit together? Oh I know--we're all mind readers.
89Suburban
SE PA
I'm getting a P300 code, thoughts? Engine light is flashing as well.
89Suburban
SE PA
I think you have a misfire...;)
You probably also have the ABS light on and traction control/stabilitrac off.
Yes traction control light, flashing engine light. Could there be air trapped in the fuel rails? Possible to put the wrong plug on an injector? Everything looks legit, no leaks, good oil pressure.
All the plugs nice and tight? Bolts too?
CKendrick
