****** figuresWell...I forgot to read the fine print as in applications for the Dorman part. It’s for earlier models, 80’s-early 90’s so my fuel cap doesn’t fit and the one that will probably work is about $90 so I’m gonna see if I can modify the old one to fit the 2” hose and it looks like it will work, if not I’ll order the other one.
Bummer..!I got the correct Dorman filler neck today and pre-assembled the parts. I pulled the overflow hose off the fuel cell and found another bigger hose to make the transition to the larger nipple that’s on the new part, got everything ready. My plan is to pull the old base off the cell, cut the spout off it and enlarge the hole in the flat plate that’s left over to match the new base, mount the new base to the old one since it will mount inside the original bolt holes, and remount the old base plate with the new assembly attached. Simple. I was hoping the old base was attached with bolts threaded into the cell, with no nuts on the inside. I carefully started removing a bolt, pushed on it.. seemed like no nut and it was threaded into the aluminum. I proceeded with removing it. It was almost out when I heard the “tink”. A nut falling to the bottom of the tank. Dammit. I need to drop the cell and remove the pump in order to get my hand inside the tank to do this, so I put it back the way it was for now with a rubber grommet in the hole so I don’t get an evap code. I’ll do this project later, I don’t want this truck down until The Beast is driving again. I know one thing- this will take the gas fast when I’m done, the 2” hose is huge.
View attachment 246604 View attachment 246605
Honestly, it provides me with the opportunity to have a bigger fuel cell made. The 15 gallons sucks since usable fuel is more like 12. I looked at pre-made cells when I had the bed off but nothing would fit. I will probably have a 20-22 gallon one built that will accept a full height pump. I had to cut the height down on the Delphi pump I replaced last year because the cell isn’t tall enough. I have room to go wider by at least 10” and then I would go 2” taller. The area where the pump mounts is hamburger from all the holes the PO drilled in it mounting pumps. The mounting ring has holes drilled at random places in the circle so as it was r&r’d a few times they just ran the self tapping screws into new holes. It was a mess. I’m going to see if there’s any place local that can build one to my specs, and buy a new pump. That way I can cut the holes and mount everything myself so I know it’s done right.Bummer..!
Every PITA is a new opportunity to improve the existing problem. [emoji16][emoji106][emoji631]Honestly, it provides me with the opportunity to have a bigger fuel cell made. The 15 gallons sucks since usable fuel is more like 12. I looked at pre-made cells when I had the bed off but nothing would fit. I will probably have a 20-22 gallon one built that will accept a full height pump. I had to cut the height down on the Delphi pump I replaced last year because the cell isn’t tall enough. I have room to go wider by at least 10” and then I would go 2” taller. The area where the pump mounts is hamburger from all the holes the PO drilled in it mounting pumps. The mounting ring has holes drilled at random places in the circle so as it was r&r’d a few times they just ran the self tapping screws into new holes. It was a mess. I’m going to see if there’s any place local that can build one to my specs, and buy a new pump. That way I can cut the holes and mount everything myself so I know it’s done right.
FYPEvery PITA is a new opportunity to spend more money.[emoji16][emoji106][emoji631]
That too.. [emoji16]
Time for a fuel neck upgrade. The new cell
is on hold until I can find somebody to build it. I found the nut I lost.
View attachment 246925 View attachment 246926 View attachment 246927
I cut it slightly bigger than the new one. That shit was thick steel too, 3/16” or 1/4”. And thanks.Did you cut that mounting plate to match the new filler neck base opening or leave it like it was? Looks real good dude, nice work.
In a world where you lose more than win it is truly the small wins that make the difference.I just filled it up, what a difference. Put the nozzle in, click it on, don’t even need to hold on to it anymore. The other one always spit a bit of gas out too just as it finished and clicked off. Not anymore. Yay. It’s the little things.
