PPV12HOE
NC
Ordered sway bar links and bushings... front and rear... and a set of rear shocks... more fun for the weekend if they get here on time...
Kee Fuller
las vegas
New wheels for me. Might put em on this weekend. Bumper Air dam is laying on top of them
Kee Fuller
las vegas
For some strange reason the oem air dam didnt fit on my aftermarket bumper and now this air dam doesnt fit either. Almost like the aftermarkey bumper is longer. Ah well, gonna drill a hole and make it fit
I've been a bit disappointed in mine. The first issue is that the rubber strip that sort-of seals against the rear body popped out the first week. I glued it back into its slot. But it worked itself out again a few weeks later. I ended up leaving it off, with no apparent consequence. Then last week, I noticed the center of it had distorted so that it sags a little below the contour of the roof. It's only low by about 3/16". And it's not super noticeable above my line of sight like it is. But still, I'd expected better after only 13 months.
weird the housing looked pretty good, I already had a esky housing that was painted to match so I just used the led light and sold the housing to someone else
sonic_the_hedgeh
Gotta give a high-five to @kbuskill for the help, blue to blue and red to ground worked! No more led hyperflash on the Yukon only took me 3yrs to do finally do it, lol I soldered those on and ziptied it to the light harness, good to go
So if I get this straight you had problems with LEDs bulbs on a Yukon?
Just noticed this article and I did my 2004 Yukon Denali with led low beams and no flash. Didn't need the anti flicker boxes for them. Surprized actually that it was so easy, although I will say it is a slightly more difficult to put the assemblies back into place.
Sent from my CLT-L04 using Tapatalk
only problem I had was hyperflash on the blinkers when using led marker bulbs, I should have installed resistors when I put them in but figured I might get the bcm flashed instead just never got around to do anything about it until recently. This wasn't in reference to LED headlights I prefer to use HID's myself
Bigkevschopshop
Northside H-Town
Nice! How'd he like it? I really like these in 2 doors. Had one for years. Couldn't kill that 4.3. Trans is another story tho.
He deff likes it, yeah the 4.3 is pretty strong and hard to kill, I really wanted a 2 dr but couldn't complain with the price on this one, was a show truck for a few years of its life, not radical but was lower. Well maintained, just a few things to fix and good to go.
Good Dad=Lucky kid.
Monz11
Da Burg, Fl
So, I decided to rip the Hoe down yesterday, and start installing the LT TSP headers, AFM/ DOD Delete kit, camshaft, VVT dekete kit. I had to take off the rt fender, bc some ****** decided to come over in my lane without looking. Damn Canadiens, just cant drive!!
I have some more to do, but ordered new ac compressor and water pump.
Anyone, have any suggestions on throttle bodies, ac condensor, and tranny cooler upgrades?
1BADI5
DMV
I installed the Tru Cooler Max trans cooler.......great results for the cost. Dropped my temps 20-40* on average.
For the throttlebody, I ordered a LS7 TB and ported it. Simple plug and play bolt on. I also ported my intake manifold......since I had the time and equipment. Still waiting on a dyno day to see the actual gains.
Monz11
Da Burg, Fl
Did you port the intake manifold yourself or send it out? I looked at buying an upgrade online, but the $$$ was crazy insane. I was thinking of getting it ported, but not sure whom to trust, etc.? I guess my machine shop could do it...
Kee Fuller
las vegas
Got a good deal on a set of tires. Nexen roadian hp. Dude wanted 500, gave him 400. I got the same tires in 17 on my rig now. Lug nuts came in today. Getting put on tomorrow.
1BADI5
DMV
I ported it myself: my LS7 TB and intake manifold
I was porting LSA blowers, TBs and MAFs for awhile.......but work and school cut into my free time.
I port/gasket matched the runners.....there is ton of material to take out there. I also opened up the throttlebody opening quite a bit too. I think I posted the pics up in my build thread.
HeavyHoe03
