I didn't see the little one, that's a good place also I just want to use a bump switch and then I can wire it to the buzzer portion of the police unit, I have the speaker but it's pretty big and heavy like 40lbs I have been sort of looking around for a more reasonably sized one that I can fit behind the front grill on the bumper
Way down on my To Do List is a Whelen SA315 to go with their PAP112, an electric air horn and microphone. Oh, and a SAK24 bracket made for our trucks but that will interfere with your transcooler.
PPV12HOE
NC
This happened today....
the_tool_man
Upstate South Carolina
Ordered a 3rd brake light for the yukon will update after it gets here!!
I've been a bit disappointed in mine. The first issue is that the rubber strip that sort-of seals against the rear body popped out the first week. I glued it back into its slot. But it worked itself out again a few weeks later. I ended up leaving it off, with no apparent consequence. Then last week, I noticed the center of it had distorted so that it sags a little below the contour of the roof. It's only low by about 3/16". And it's not super noticeable above my line of sight like it is. But still, I'd expected better after only 13 months.
St. Louis
I'll have to keep watch on mine. It's only been installed since early/mid December.
2001 Yukon SLT
2012 Yukon Denali XL
2011 Yukon Denali RIP 5/20/18
Staggered 02
Those brakes will look and perform great as you already know. I will be installing my redone brakes on the Crew Cab while I am sheltered at home. I don't like the fact that the lettering has faded off.
Staggered 02
No problem. I saw it when I was looking for an intake to replace the ugly stock one on my Silvy. But I don’t need anything near that one. 102 mm is good for what, 800 HP? I know the stock is good for 450-500. I just want a clean looking intake, I’ll probably get one of the welded aluminum ones idk.
That LSx Intake would look great in that engine bay. Cleans the engine bay up quite nicely.
Candielaine
