You win!No no no. He gets the bender out and does it like a man. Chicago style.
Nice.. link?Doing some tidying up of wiring. I really like these tie straps that look more like small band clamps than tie straps. View attachment 244097
Amazon.Nice.. link?
Amazon.
SecuriTie CTCH8-60100UVB Low-Profile Cable Ties, 8 Inch., 60 Lbs. Tensile Strength, Wire & Cord Management / Industrial / Household Use, Nylon Zip Tie, 100 Pk, UV Black https://www.amazon.com/dp/B06Y4C4Y22/ref=cm_sw_r_cp_tai_dvuJEbNCRV2XN
Thanks @Rocket Man. Ordered. [emoji16][emoji106]Amazon.
Not sure if you'd be interested in these since you bought the Kooks--Amazon.
I have some that came with the header wrap I bought a year or so ago. I’m not wrapping the Kooks though, they’re ceramic coated.Not sure if you'd be interested in these since you bought the Kooks--View attachment 244153
https://www.amazon.com/dp/B072WC1MX...9Y2xpY2tSZWRpcmVjdCZkb05vdExvZ0NsaWNrPXRydWU=
I don’t want my money in limbo.
Not a damn thing. I bought it to use on The Beast’s intake tube but it was a hassle so I took it off. Most of the roll is unmolested.So what ARE you doing with the header wrap?
I don’t even know where it is right now.What kind is it and how big is the roll?
The piece of tube I ordered came in today so I put my tube bending hat on and got it done. It doesn’t look like much but it’s not easy doing this. It came out perfect for once. I’m glad that part of the project is done.
View attachment 244183 View attachment 244184 View attachment 244185 View attachment 244186
nice, how do you like it? I was looking at getting some for both of my trucksI started on the door sills. The paint is scratched in a few places so I bought some inexpensive textured wrap to install. I only got the driver door done, I need to get it off the jack stands again so I can move it and get better access. I have new weatherstrip ordered for that door too since the one that’s on there is torn. I’m just finalizing a few things underneath before I drop it back down. Roger Vinci got back to me with cam, springs and pushrod recommendations but I’m thinking I’ll wait for now. He said they might get closed down soon and I don’t want my money in limbo.
View attachment 244155 View attachment 244156 View attachment 244157
It’s nice; it looks good and it will wash easily. I returned another roll that was the anti-slip type because I didn’t think it would wash easy, it was the stuff that’s more like sandpaper. You just have to be sure the surface is super clean because it’s just like any wrap- every little speck shows through.nice, how do you like it? I was looking at getting some for both of my trucks
ok I was looking at both types, so I take it the smooth stuff is pretty thin?It’s nice; it looks good and it will wash easily. I returned another roll that was the anti-slip type because I didn’t think it would wash easy, it was the stuff that’s more like sandpaper. You just have to be sure the surface is super clean because it’s just like any wrap- every little speck shows through.
Fairly thin. I don’t know exactly how thin, it’s not thin like a wrap is. It’s textured. I was trying to figure out where I ordered it from and had to clear back to January.ok I was looking at both types, so I take it the smooth stuff is pretty thin?
Not sure if I saw if you were getting a stalled convertor. If so, what speed?Ordered the cam, seals, dual springs, pushrods, ARP harmonic dampener bolt, AC Delco timing cover seal, timing cover gasket, and water pump gaskets. Still need oil filter and some other supplies but I think that does it. The engine only has 65k on it so I’m not replacing the oil pump or timing set.
And I’m no expert in cams so I’m trusting Roger Vinci that this will be a good cam for what I want:
"CHOPPER "
STREET / STRIP CAM
POWER RANGE 2000 TO 6500
TUNING REQUIRED / STALL CONVERTER RECOMMENDED
5.3L - 6.0L
HI MIDRANGE "TORQUE" / WEEKEND WARRIOR
LOVE THAT POWERFUL CHOPPY IDLE
DUAL VALVE SPRING KIT & MOLY PUSHRODS REQUIRED
DUR @ .050" 210*/218*
LIFT .552 / .552
LSA 112*
2A
