2005 Tahoe..Engine hours on DIC starting from 0
Matahoe
Military
Grand Rapids, Michigan
Odd...for some reason (maybe not?) The hour meter in the DIC shows 8 hours. It used to show around 1560 or some other bigger number (supposedly legit). Anyone know what happened here? Is my PCM overwritten?.
HiHoeSilver
Away!
Chicago
We have run into them resetting themselves, although I'm not sure that we've seen it this up close. @swathdiver? You remember this?
Mine reset when my daughter ran down the battery. It was the only thing lost, radio presets and other settings were fine if memory serves. Did you disconnect any battery cables or grounds within the last eight engine hours? Maybe a hiccup over a bump in the road? My memory is not, think it is treated like the odometer if you wanted to reflash the cluster or wherever the information is stored on the 800s.
veteran111
