Refinish headliner?
Ok. Reg cab is pretty easy, and small. Hardest part is dropping it down. Still a good price tho.
No, the hardest part is getting it out of the truck after you drop it down. Pull the back glass or windshield.
mountie
That’s one way, plus you wouldn’t even need to pull the headliner off, just turn the roof upside down.:insane:
Unlimited options to do it wrong....... Ha...
My sunroof slider-cover / fabric is falling..... I am NOT going to pull the sunroof up & out....
I wonder if I can remove the falling fabric and apply a matching material?
Forgot about that part. Gotta bend it slightly enough without breaking it. It's a heated garage, or summer job for sure.
Not 100% sure, but I think I've read the slider can be taken out without dropping the whole headliner--just the front--but I'm not positive--pretty sure tho.
Not 100% sure, but I think I've rear the slider can be taken out without dropping the whole headliner--just the front--but I'm not positive--pretty sure tho.
Pickups usually gotta pull the back glass. Extended or CC’s for sure, not sure about regular cabs.
Matthew Jeschke
Matthew Jeschke
Sahuarita, Arizona
joann fabrics has that color. is dirt cheap, just not side enough for whole headliner... but aunroof, no problem and you can remove that door without much hassel.
Sent from my SM-A505U using Tapatalk
Got my GN headliner material from there. Cheap.
Ihaveatahoetoo
