Seized Valve Cover???
Anybody ever have an issue with a valve cover that won't come off? Im trying to check my rocker arms. My suspicion is that the #7 is loose causing the rattling, rather than a compressed lifter. BUT i can't get the damn valve cover off! All the bolts are removed. There's not much to brace myself with too get enough leverage. I feel like this is a sign of something bad... HELP!!
Multnomah Falls
Military
If you have a rubber mallet tap on the sides to help break free. Slight prying with a pry bar could help as well but be very tender when you do that. I mean tender tender or you will crack/break the cover.
They can be sticky. Don't be scared to get rough with it, just don't focus all your rage to the point of a flathead screwdriver or you can crack the cover and/or gouge the head. You need a wide surface to spread out the force and with something a little softer than the metal. So stick the edge of a 2x4 against the edge of the cover and whack it with a hammer. You'll have room to swing with this method and the wood will give before you damage the metal.
wjburken
Eastern Iowa
I have a plastic dead blow hammer that I like to use in situations like this.
mcpole
You probably have a lifter issue making the noise, but a rubber hammer works well to loosen the cover
mlitefan
