R3cord303
Posse In Effect
Oregon Valley
Why not? Have the downstream O2 sensors tuned out. The cam won’t matter unless it sets DTC’s. And Oregon inspectors don’t look for cats in a visual inspection. Mine passes with a cam and O2 sensors tuned out. They’ve never looked to see if there’s cats installed with my headers, and Im loud as hell. Passed last time in 5 minutes.
Do the areas here that require testing not shove a sniffer in the tail pipe?
Super Moderator
Elev 5,280
They can do either one here in Colorado (along the Front Range), and I'm not sure how they pick which one. My Fusion passed two years ago with the OBD test, 5 min. max., no numbers documented, just pass/fail. Last time they did the IM240 test on the dyno, and for that one I got actual emissions numbers.
EDIT: these are the IM240 results for my 2008 Fusion with 115K on the clock. The OBD-only test just reads the readiness of the different emissions systems.
Sam Harris
Every time I’ve done it in this state, they do the actual dyno test. The exception are vehicles built prior to 1982 IIRC, and with those, they use the tailpipe sniffer.
Super Moderator
Elev 5,280
When I bought mine in 2016 they did the dyno test. Next test, in 2018, I didn't have to go to the test place because I had driven by several of the remote testers they have on some of the highway onramps and streets. You can find out online where those are located. I think it takes two tests a couple of months apart to allow you to bypass the test place. Still have to pay the $25, though, when you renew the tags.
R3cord303
Posse In Effect
Oregon Valley
How the hell does that work?
Richard A
