05Single's virgin build thread. 03 tahoe
eand28
Pennsylvania
05Single
05Single
afraid of the dark
So I wanted passive blue demon eyes. It sorta works. Used a Pepsi can to get a super reflective blue for more blue appearance. Not sure if it works yet. Painted the bixenon cutoff shield blue. I think this dark blue was a bad choice and should went with red or white like I showed in my previous post on page 85 awhile back but oh well , maybe next set .
It’s just the one leg with the arrow pointing to it that gets clipped not the whole thing
Understood. What about the resistors wired for leds? Do they need to come off? Or can they just stay on without issues? Will regular bulbs work correctly still, with that leg snipped?
Sam Harris
Know which one?
Leg #7. Same as in the first picture as well. I suspect this leg provides the hyper-flash when resistance is lower than it’s supposed to be. So clipping it should only affect that function. (Guess..)
HiHoeSilver
Away!
Chicago
That’s awesome . Sounds crazy but you should make a how-to thread and it should be a sticky
Wholeheartedly agree. Can't believe this isn't in the "database" already.
Here's my question: If you install resistors and an led bulb fails, does it hyperflash? I kinda like a function that alerts me to a problem.
No. You’ve eliminated the alert by using the resistor, and the led has basically no resistance so it doesn’t make a difference when it goes out.
Sam Harris
Yup. On your own to continually verify all bulbs are in working order. Any LEDs installed in turns will eliminate the alert functionality.
Nothing ever alerts us when our brake lights go out anyway, which are way more important than turn signals. BTW, why is that? They could design an alert if a TS bulb goes out but not brake lights or headlights or running lights?
ScottyBoy
Shreveport, La
It can be done, it's just expensive to get the circuitry to do that. My grandmother gave me her 89 Jaguar XJ6 back around 2004 after she stopped driving. Even though it was an 89 model, it was WAY ahead of it's time as far as the electronics in it. Each tail light and front turn signal had a "bulb module" (which was basically a damn $450 computer module). These bulb modules would trigger a warning message on the dash if a bulb was out. And it told you exactly which bulb!! For instance, it would say "Left stop light bulb failure" in the message screen on the dash. But it was also a PITA when I had a bulb module go bad. Kept giving false bulb failure warnings CONSTANTLY, and it was almost $500 for a new one. I found a used one online for under $200 which was still expensive as fawk in my opinion, lol .
05Single
05Single
afraid of the dark
What I learned in driving school, always do a pre trip inspection before driving:lol:
05Single
05Single
afraid of the dark
$500 is insane money for 1989. That’s like a weeks worth of pay back then
scottd
