Pavel's 2005 Escalade EXT build
adventurenali92
Big Bear Lake, ca
Great progress! I love the EXTs as well. I’ve always wanted one! I’d love to see what the outside looks like as well! The stereo headunit looks awesome! It looks clean and OEM! Great work man!
iddqd
iddqd
San Francisco, Comifornia, USSA
Only minor mods outside so far, and you can see them all in my signature picture: 18" wheels & tires, headlights, mudflaps, flexy antenna.
HiHoeSilver
Away!
Chicago
Audio
Head unit: Joying JY-UM135N2, later upgraded (manufacturer offered upgrade in a form of a new core board, I didn't have to replace the whole unit). Specs: Android 8.0 Oreo, 4GB RAM+32GB ROM, 128Gb SD card (bought separately for music and maps), Bluetooth, rear view camera. It a royal PITA to install a camera in the tailgate of EXT, since it's made of fiberglass and glued together with a double sided scotch tape. But I did it, and also when I was there, I installed a lock actuator, so now the tailgate closes with the remote like all other doors.
It runs Android, so basically the entire Google Play is available. I installed Waze, Torque Pro, Maps, Poweramp and a bunch of other useful apps. I also bought a Dash cam, so now I record everything. It looks neat and factory.
Amplifier: https://www.clarion.com/us/en/products-personal/marine/XC2510/index.html
All speakers are factory so far, I am waiting for them to die, so I would have a justification for a set of a new speakers.
A sub is factory as well.
View attachment 218086 View attachment 218087 View attachment 218088 View attachment 218089 View attachment 218091
Which cameras are you using with it?
iddqd
iddqd
Rear view camera
I installed a rear view camera in the tailgate. That was a PITA!!!
Some engineer (if that's the right word) at GM decided to make tailgate out of fiberglass. To put the parts of the tailgate together they used double sided sticky tape. To add insult to injury, GM didn't put a lock actuator inside, so the tailgate can only be opened and closed with a key. And it's very heavy, but no torsion installed.
To be fare, in 2007 GM did their homework and the new Avalanche/Escalade EXT had a regular metal tailgate with a power lock, torsion bar and a rear view camera. But for 2002-2006 the owners have to do it themselves.
To take tailgate apart, you need to cut the above mentioned sticky tape. I used just a regular kitchen knife. All the rest is very easy.
So, I installed the camera, a tailgate lock actuator and a torsion bar.
Pix speak louder then words:
20180205_081705.jpg 20180205_081713.jpg 20190307_145430.jpg 20190307_145435.jpg 20190307_145443.jpg
adventurenali92
Big Bear Lake, ca
Did you have to run a wire from the tailgate somewhere up in to the truck to get it connected to the headunit?! I’ve always been curious about that.
iddqd
iddqd
I took out a right bed panel (a major PITA!!!) and ran the wires their, then connected power lock wires to door lock wires, so it opens and closes with the other doors. And the camera cable runs all the way to the dashboard.
I didn't want to run wires on the outside, as it would be subjected to elements and I am not sure that a video cable is rated for that.
adventurenali92
Big Bear Lake, ca
Smart thought on the door locks! Yeah I would think the video cable would have to be covered. I have a back up cam installed with my headunit as well. But I had it installed because I don’t have the experience or skills for that. Lol. And have always been curious about how they worked the backup cam.
iddqd
iddqd
I think u've got a Suburban. Its so much easier to run the wires on SUV than on SUT. BUt it's usually done under the door frame trims, where floor panels meet door frames
adventurenali92
Big Bear Lake, ca
Yukon XL but same thing. Lol. Just seems like a lot of work I guess. I would think it’d be easier to have some sort of receiver that runs off of a signal rather having to run that cable all the way forward. That’s a lot of cable. But what do I know about these things?! Lol
ArcticYukon
The White Yuke has been superseded by a Red Hoe
Dry Ridge, KY
Rear view camera
View attachment 218211 View attachment 218212 View attachment 218213 View attachment 218214 View attachment 218215
Nice work, man!
iddqd
iddqd
There are actually wireless camera, but I didn't want to add complexity where it's not needed. Plus, they all are made in some Chinese basement, which doesn't contribute towards reliability either, The fewer points of failure, the better!
adventurenali92
Big Bear Lake, ca
Ah ok that makes sense
05Single
afraid of the dark
Nice work . Great to see you do a full job and not half ass it .
Side not looks like your apartment has a nice view. 7th floor?
iddqd
iddqd
Ground floor actually, but it's on the top of the hill, near Twin Peaks. But I moved out already. The apartment was very nice, but for 2 people and a German Shepherd Dog 1BR is waaay to small. Now I live in a 3 story townhouse in South San Francisco with my own garage, 2BR, 2.5BATH, but rent is actually the same. Welcome to San Francisco :)
Ah, and I cut my commute time in half
05Single
afraid of the dark
Awesome upgrade on the home , I thought San Fran was expensive
Drewphil
