Door sag
Squirrelsmith
Went through a high pressure car wash last week and washed my passenger seat. Look into it and my doors are sagging bad. So i replaced the pins and bushings... no difference.
I can feel to play when i wiggle my door up and down.
What is happeneing to me?
Wedge
Is the plastic bushing on the striker still ?
Wedge
Ok looked at the part here in the store. Sorry, it doesn't have a plastic bushing like other GM's. However you may want to look into replacing it. Dorman #38428 @ Autzone.
Big Mama
Virginia
The door shouldn’t move up and down any noticeable amount with it open or closed. If it sags the structure is bad/loose/etc. start with the hinges and the support behind them use the driver door as a reference you may have a stripped bolt hole or a backing plate that came loose from the cab or door
Uderro1
Definitely check the hinges. I know my driver's door sags because someone was hanging on it.
Squirrelsmith
Squirrelsmith
I got a pin and bushing kit from doorman. total garbage! don't buy them there is all kinds of slop between the small bushing and the pin
alpinecrick
Western Slope of Colorado
If the door is still sagging after replacing the pins and bushings the door pin holes in the hinges are probably wallowed out and are elongated.
Two fixes: The holes can be welded and redrilled. Need to redrill the holes in the precisely centered spot or the door wont close/fit properly.
Or replace the hinges. The factory hinges are welded to the door frame so the welds have to be ground off and the new hinges are installed with bolts and those bolt holes have to be drilled into the A pillar and into the door.
go the to a real hardware store and look for a sleeve or have some made by a machine shop, there is a few on ebay but you may have to message them for specs
Squirrelsmith
Squirrelsmith
The bushings for the pointed end of the pin are just overaized ones that are crushed a little to be ovalized. Pretty cheesy
the 18th letter
Northern New Jersey
View attachment 220354 View attachment 220352
Don't go too long without replacing them or you may end up with the hinges wallowed out also......:)
I'm gonna guess they are since the bolt that catches the door lock is showing wear and I've shaved about an 1/16 occasion metal off the top corner of the rear driver's door smh.
alpinecrick
I'm liking that idea. It would be a whole lot easier than the other options.
Come to think of it, somewhere on ebay I saw oversized bushings. Possibly allowing a guy to just drill out the pin holes a little larger and inserting the oversized bushings.
Squirrelsmith
Squirrelsmith
ok there was water dripping on the floor as i was driving it's time to get serious
Hodmjstone
