Door sag
Squirrelsmith
Went through a high pressure car wash last week and washed my passenger seat. Look into it and my doors are sagging bad. So i replaced the pins and bushings... no difference.
I can feel to play when i wiggle my door up and down.
What is happeneing to me?
Wedge
Is the plastic bushing on the striker still ?
Wedge
Ok looked at the part here in the store. Sorry, it doesn't have a plastic bushing like other GM's. However you may want to look into replacing it. Dorman #38428 @ Autzone.
Big Mama
Virginia
The door shouldn’t move up and down any noticeable amount with it open or closed. If it sags the structure is bad/loose/etc. start with the hinges and the support behind them use the driver door as a reference you may have a stripped bolt hole or a backing plate that came loose from the cab or door
Uderro1
Definitely check the hinges. I know my driver's door sags because someone was hanging on it.
Squirrelsmith
Squirrelsmith
I got a pin and bushing kit from doorman. total garbage! don't buy them there is all kinds of slop between the small bushing and the pin
Luggz
