Magnuson Supercharger, Valve Train and other supporting mods. 2007-2013, 5.3L Chevy Tahoe
Chrismnj
Chrismnj
NJ
Moroso 41205 Heavy Duty Transmission Cooler/Filter
NGK Spark Plugs BP7EFS/3526 - NGK Standard Series Spark Plugs
kbuskill
NE. FL.
Chrismnj
Chrismnj
NJ
Does anyone knows the CFM rating of stock 2012 tahoe radiator fans?
Chrismnj
Chrismnj
NJ
Just trying to find out if its beneficial to change them, last think I wanna do is to replace with less efficient.
mikeyss
Longmont, Colorado.
My 09 L9H Tahoe surprisingly didn't have the K5L option, even though it has the external trans, oil, and power steering coolers. I did upgrade my efans, I swapped my efans for the ones that come with the 2012 K5L package. Now, When my fans are on hi, I swear it will suck my shirt off when I'm standing in front of it.
Since I got my BBP tune, they come on low speed sooner than stock, and in summer they run on high speed more often, which is good IMO, keeps the A/C and engine temps lower that way.
Sam Harris
Sam Harris
whats up with the hole/tube in the bottom - is that to fill it? i think some 6l80 cars dont have a fill tube
looks real nice
Isn’t that where the filter mounts?
Sent from my iPhone using TapaBlah
Chrismnj
Chrismnj
NJ
Now the plugs on the side of a pan, do you guys think i could plug my moroso trans cooler to that? So I don’t have to tap in to the stock one?
kbuskill
NE. FL.
No... your cooler has to be on a pressurized line... the pan isn't under pressure. If you hooked your cooler to the pan there would be no pressure and therefore no flow of fluid through the cooler.
97audia4
I am looking forward to the pan install on fitment , I have been looking for something like this . I don't need the extra 3 quarts like most other brands.
Drewphil
