Magnuson Supercharger, Valve Train and other supporting mods. 2007-2013, 5.3L Chevy Tahoe
Chrismnj
Chrismnj
NJ
1. Magnacharger TVS1900
2. BlackBear Tune
3. Airaid 202-270 AIRAID MXP Series Cold Air Dam Intake System
4. Kooks Y-Pipe 28553200
5. Kooks Longtube Headers 28502400, *ceramic coating
* Magnaflow exhaust already installed
6. Moroso 85481 Air/Oil Separator
7. Auto Meter 17118 Triple Pillar Gauge Pad
8. GlowShift Black Gauges
9. Accel 9070C Extreme Ceramic 135 degree boot Plug Wires
10. AC Delco 12673134 Oil Pressure Sensor
11. AC Delco Ignition Coil D513A
12. ACDelco 12617944 GM Original Equipment Exhaust Manifold Gasket
13. Stage 8 8900 Locking Header Bolt Kit for GM Small Block
14. NGK Spark Plugs BP7EFS/3526 - NGK Standard Series Spark Plugs
15. BTR POSITIVE DISPLACEMENT SUPERCHARGED STAGE I CAM FROM CAM MOTION, CM32338206
16. .660" Lift BTR Platinum LS Spring Kit; Titanium Ret., .505" ID .060" Thick Loc., Black Seals, SK001/T/0560/BB
17. BTR Chromoly One Piece Pushrods; 7.400" Long, 5/16" Diameter, .080" Wall, Set of 16, PR7400312-16
18. BTR GM LS ROCKER ARM TRUNNION UPGRADE KIT TK001
19. CAMSHAFT INSTALLATION KIT
20. COMP CAMS TRUNNION TOOL FOR LS ENGINES; CC54702-TL
21. Hummer GM OEM 08-10 H3-Engine Motor Mount Torque Strut 25847739
97audia4
How much boost do you plan to run? You are also smaller cubic inches... I would talk to Nick @ BTR ([email protected]), he does the custom cam sheets and knows what he's doing. My idle quality is just fine and I LOVE the sound of the cam. It certainly makes a crap ton of power too. You won't be disappointed with any of them honestly. What heads are you running?
***Now that I'm thinking about it, that rev video was with the stock 6.2L and the LSA blower when I first did it... The BTR Cam was installed when I built the 402" motor so all the videos after that.
How did you like the LSA on the 6.2? Thanks to the OP this thread has pushed me into going S/C as well.
67RS427
It was great and ran awesome with the stock VVT cam... Probably made around 600hp on a non flex fuel pump and stock CTSV injectors.
Chrismnj
Chrismnj
NJ
should I go for new cylinder heads?
randeez
south florida
lol nah man, get the thing together and running and see what you think...its a blower....pulley down , get more injector and pump and let it eat if you want more power
Chrismnj
Chrismnj
NJ
Vortech High-Flow Fuel Injectors 8F060-005
randeez
south florida
i say go bigger, those show as 43lb, that is about what the 6.2 flex injectors are at 44psi. if your truck is a flex fuel truck the in tank pump should support 60lb decently. the usualy upgrade is to 80lb(850cc) or so. if youre using fic or fid the cost is about the same. you can get cheaper ones but to keep the fpcm happy (and functional) you need to adjust some values in the tune
Chrismnj
Chrismnj
NJ
many of them say don't fit flex fuel
Chrismnj
Chrismnj
NJ
are any injectors provided with the maggy?
that is a good question. still in the box lol, I did see a Bosch package, now you gonna make me go and check.
Edit.
No, they don't provide injectors.
67RS427
Edit.
OEM CTSV injectors will get you pretty far and do just fine at 10psi. I have a set with less than 15k miles on them. They usually go for $225 or so. Yours for $175 shipped if you want them, PM me.
*stock CTS injectors are 56lb btw. Lots of CTS guys are making 600whp with stockers. For reference, I'm running 1000cc (95lb) FIC injectors and I've never seen more than 45% duty cycle. You won't need to spend $800 on injectors at your power level... Your idle quality will just get worse and then you probably have to scale your entire tune
Chrismnj
Chrismnj
NJ
Iam thinking to bolt everything on get it running and see what it does, thank you for your offer, will keep in mind, also it will just get harder to diagnose when something goes wrong if I start messing with fuel now.
67RS427
Agreed, that's the smart thing. See if you even need the extra fuel first. Make sure you keep an eye on that wideband though, don't wanna lean out and hurt something. It's always nice to use OEM parts when possible so if you have a problem you can go to any store and get a replacement.
Chrismnj
Chrismnj
NJ
I am more concern about transmission now, what do you think how far stock will go?
Drewphil
