New rear air compressor not working
Cthomas
I have a 2007 delanli that I replaced with a new rear air compressor. It isn't turning on. I checked all the fuses and relay and all seem fine. I am at a loose. It has power to the compressor and I also made sure the new compressor works. It's doesn't seem to be getting signal to turn on , not sure where to go from here.
Do you have or have access to a quality bi-directional scanner. With a scanner, you can perform tests on the active suspension system, which includes the compressor, and this will steer you to the root cause of your issue. If I were to guess, your suspension control module has failed, but don't simply shoot the parts cannon at the issue.
Drewphil
