Magnuson Supercharger, Valve Train and other supporting mods. 2007-2013, 5.3L Chevy Tahoe
67RS427
I hear you. I can see myself going crazy with engine modes, hope not, fingers crossed.
Once you get that bug it doesn't go away... I started with a simple rebuilt blower on my stock 6.2L with 150k miles on it. Ran it for about 6k miles until the oil pressure started dropping from the sloppy main bearings. Trickle affect from there but I couldn't be happier with the result. Either way you will end up rebuilding your 6L80 at some point. Heavy trucks, AWD or 4x4 and lots of power don't do the transmission any favors. Stock 10 bolt rear/axles are more than strong enough if you replace the G80 center section with a TrueTrac. I'm still running my stock transfer case as well with zero issues (163k miles). Front diff I rebuilt with better bearings but original ring and pinion front and rear for me still. I'm not sure how much of a hands on person you are but I encourage you to learn to tune your own car with HP Tuners. I'm learning myself and luckily I have a friend that is a GM Engineer to teach me how the ECU/controllers work but you will be way happier if you learn whats going on with the engine and can make small changes yourself. There is no tune or tuner that can make a one and done tune. You will be back and forth many times to get it how YOU want. I'm still tuning and making changes every day I drive it...
Chrismnj
Chrismnj
NJ
I think I am pretty handy, like to do most of the modes myself, but this being said I am new to Tahoe world, wish I could find someone locally that knew about them more, I know stock Tahoe is not ideal truck for off road but at the same token is a good base to make it. Don't have a problem spending money on drivetrain just want to do it right. Main point is reliability, and I do need help to get there, so any advise is greatly appreciated.
Chrismnj
Chrismnj
NJ
question for guys who have widened O2 sensor A/F ratio gauge, where did you place your sensor?
67RS427
Right where the Y pipe merges together if you only have one. I plan to add another so I can monitor both banks though. If you have cats, you want it before the cat 12" or so after the collector
67RS427
This is my first Yukon as well. It's just a GMT900 truck underneath so there should be plenty of people around that know how to work on them. I didn't know much about them when I started but now I know my truck front to back. Not a single bolt or chassis ground I haven't touched
Chrismnj
Chrismnj
NJ
Right where the Y pipe merges together if you only have one. I plan to add another so I can monitor both banks though. If you have cats, you want it after the cat 12" or so
very tight there
Chrismnj
Chrismnj
NJ
some times I wish I had the suburban lol
67RS427
some times I wish I had the suburban lolView attachment 213604
Are you keeping your cats? Plans for the rest of the exhaust? I couldn't be happier with my Kooks Headers/Y Pipe and OEM pipe back with a magnaflow muffler. You have smaller pipe so you may wanna do a cat back and get rid of that resonator.
Chrismnj
Chrismnj
NJ
for now I ma keeping it, will see after SC installation, if the number are disappointing might go further.
Chrismnj
Chrismnj
NJ
Mine being a 6.2L, I have 3.5" stainless from the Y pipe back. I put mine on the passenger bank knowing I was going to add a second one. Ideally with one, you'd want it before the flex pipe after the Y. Your pipe looks much smaller though, not sure if you have the flex pipe.
my Y pipe is 3.5" than goes down to 3"
Chrismnj
Chrismnj
NJ
FYI. Info copy and paste from AEM web site.
What does Air/Fuel Ratio (AFR) mean?
AFR is the mass ratio of air to fuel in an internal combustion engine. The AFR is an important measure for performance-tuning reasons. If exactly enough air is provided to completely burn all of the fuel, the ratio is known as the stoichiometric mixture which is defined as an 14.6 AFR ratio. The lower the AFR the richer the mixture. The higher the AFR the leaner the mixture.
  • 6 AFR - Rich Burn Limit (engine fully warm)
  • 9 AFR - Black Smoke | Low Power
  • 11.5 AFR - Best Rich Torque at Wide Open Throttle (WOT)
  • 12.2 AFR - Safe Best Power at Wide Open Throttle (WOT)
  • 13.3 AFR - Lean Best Torque
  • 14.6 AFR - Stoichimometirc Air/Fuel Ratio Value (Stoich)
  • 15.5 AFR - Lean Cruise
  • 16.5 AFR - Usual Best Economy
  • 18 AFR - Carbureted Lean Burn Limit
  • 22+ AFR - EEC / EFI Lean Burn Limit
Chrismnj
Chrismnj
NJ
That's pretty neat... never seen one of those before. I have always just had a local exhaust shop weld a bung into my pipes if needed.
Decided to go with the because of its good reviews, I guess if it fails it could get weld in.
Drewphil
